416ci Stroker Motor... Need Camshaft...Need Advice
I am building a 416ci stroker motor for my c5. Its going to have 12:5:1 compression. I am not a cam shaft expert. I need some advice on what grind camshaft i should use. I know i want a high lift around .670/.670 and i want the duration somewhere between 236 and 248. LSA I have no clue what the purpose is.
Does anyone have any recommendations?
The piston is fly cut -4cc for ls3 heads.
6.125 rod
4.00 stroke
4.070 bore
Ls3 Heads
6.2 Aluminum Block
6.125 rod
4.00 stroke
4.070 bore
Ls3 Heads
6.2 Aluminum Block
6.125 rod
4.00 stroke
4.070 bore
Ls3 Heads
6.2 Aluminum Block
6.125 rod
4.00 stroke
4.070 bore
Ls3 Heads
6.2 Aluminum Block
https://ls1tech.com/forums/member.php?u=210
Go with a custom grind cam talk to "Patrick G" on here. Just PM him everything you just told us . Let him know what you want to do and he will tell you the best cam to go with.
