Acceleration!
Old Feb 23, 2011 | 11:46 AM
LoudmouthWS6's Avatar
Default Acceleration!
Got this off another site, pretty cool read
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
Old Feb 23, 2011 | 01:04 PM
charlie_gonzales's Avatar
Thats a pretty cool thread...alot of interesting information that I did not know
I like how they did the comparisons between the dragster and a normal hemi v8, the tt vette, a welder, and the jet, and everything else
Old Feb 23, 2011 | 01:32 PM
imperial07's Avatar
supposedly it takes 800hp to turn the blower on a TF car.
i still can recall alot of people thought a TF car never went past 7k rpm during a run, i use to have a picture of the kendall TF/FC car lifting the blower off the engine at 7500rpm just pass the starting line.
Old Feb 23, 2011 | 01:41 PM
texas94z's Avatar
2JZs are still faster...
Old Feb 23, 2011 | 02:05 PM
cambirdracing's Avatar
Those stats are about 6 years old.
They are closer to 8000 hp. 8300 redline-that is what NHRA has the rev limiter set at. They are close to 270 at 1/2 track. Of course they went to 1000' racing, but still run over 320. I was working the last turn off in Houston when it was still 1320, I think it was Doug Kalitta went 331 (the fastest speed at the time), it didn't take him long to cover the last 1/2 mile of shutdown area. Also, when you are 1/2 mile past the finish line, you can't hear them until they are close to the 1000' mark.
Old Feb 23, 2011 | 02:06 PM
Ws6kid.'s Avatar
wow great read.
Old Feb 23, 2011 | 02:26 PM
alexus6798's Avatar
Interesting!!!!!!!!!!!!
Old Feb 23, 2011 | 04:27 PM
Jake_the_Snake's Avatar
Old Feb 23, 2011 | 05:26 PM
99FRC's Avatar
I like the 200MPH comparison. It's hard to comprehend that you would get beat to 1/4 mile passing someone at 200MPH!
Old Feb 23, 2011 | 07:20 PM
ProStreet_632's Avatar
Nothing like a Top Fueler
