Anyone a electrician? need some help
#42
Power under the hood, power at the headlight switch, the ground I had before wasn't working
Power at the glove box int. Light fuse, and the rap fuse. No power at mall fuse.. What now?
Mall is suppost to have something to do with the BCM.. Witch has to do with security. I looked and looked but cant find anything out of place. Pulled up half the carpet and theres notthing left in the dash but wiring and i just dont see anything.
So i guess i need to figure out what i should be testing on the BCM.. I dont have any wiring in my manual for it though.
#49
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Let me dig up the BCM schematics. BRB
Here, use these.
According to what I have, get the BCM out, and check pins F and K. If you get nothing out of there, the relay in the BCM is no good.
Check on C3.
And if the relay is no good, I know on the f body cars, you can usually take it apart and it will have a bad solder joint. Heat it up with a fresh dab of solder, and you're back in business
Here, use these.
Check on C3.
