Power Steering Pump
Old Mar 5, 2011 | 09:50 AM
rod214's Avatar
Default Power Steering Pump
Has anyone replaced their power steering pump ? And is it hard , can you use hand tools , or should I just take it in to an auto-repair shop and let them do it ?
Old Mar 5, 2011 | 10:02 AM
chon79's Avatar
Easy bro! Go to autozone and rent the power steering pulley removal tool. After that you will see 3 or 4 Hex bolts. Remove them and the pressure line on the side of it. Done!
Old Mar 5, 2011 | 10:57 AM
ramairracer's Avatar
just remove the upper water pump hose out of the way. use the removal tool, then undo bothe pressure and return lines, after that depending on the year should be 2 or 3 13mm bolts that hold the pump.
if your new pump came with a resivor its easier but if not you have to tap out the locking tangs on it and transfer the resiovur to the new pump
install pump and lines, and then use tool to reinstall pulley reattach coolant hose and done,
should take no more that 30 min
Old Mar 5, 2011 | 11:43 AM
sprayedz06's Avatar
did it about a month ago, not hard at all. just the pulley removal kit, some hand tools, and you should be good.
Old Mar 5, 2011 | 12:57 PM
jdoyle's Avatar
what did you do buy as a replacement or where did you buy your replacement?
Old Mar 5, 2011 | 02:48 PM
mitchntx's Avatar
http://www.pscmotorsports.com/home.php
For $100 you send them a pump and you get a pump back in just a couple days that has been rebuilt and modified so that you never have a heat and flow related failure again.
If you've ever heard of a Turn One pump, this is better in that it's about 1/3 the price.
Old Mar 5, 2011 | 02:56 PM
jdoyle's Avatar
werd to your mother. thats what i did based off of a recommendation from you in another thread that you posted in. thanks
Old Mar 5, 2011 | 03:38 PM
rod214's Avatar
Default Thank's
Thank's for the response , sounds easy enough to do it on my own !
