Need TEXAS sized help!!!!!
if the bolt is broken and the threads weren't damaged or damaged when installing, i've never had a problem getting the out. Never had to drill all the way through. Good threads mean it will come out easily.
The real PITA ones are the ones that bottom out and break or seize up and break. I bet that one would come out fairly easy with a drill/ease-out. Once it's drilled, you can probably drop the ease-out into the hole and put just the right sized socket on the other end. Seat it into the drilled hole and start turning. Drill the hole out in the bolt as big as you safely can and use the biggest ease-out that will fit.
LOL.. I was a 63B with an Artillery unit in 4ID... those damn gun bunnies can break anything. We would come in on Monday and do the PCC checks and something would be broken, even though it didnt move the week before...
we called them DAG-Bs.. Dumb *** Gun Bunnies...
HONESTLY, DRILLING THE BOLT ALL THE WAY THRU IS THE KEY. LESS PRESSURE ON THE THREADS.
