LMR - TX Mile Updates
Old 03-26-2011, 11:43 PM
  #121
texas94z's Avatar
I like how Duy rolls. A bet is a bet. However with all due respect, **** 2jzs.
Old 03-27-2011, 12:13 AM
  #122
LSX-coupe's Avatar
Sucks to here about the main bearing.
Old 03-27-2011, 01:47 AM
  #123
Moderator
98Aggie's Avatar
Originally Posted by Bryan@LME
looks like the limits of the factory oiling system on a top mile run....
Than how can a 1400rwhp vette run for 5 miles at bonneville at an avg spped of 263mph and not have oiling issues issues? Motor has been running in this car for 5yrs now.
Old 03-27-2011, 04:21 AM
  #124
02silverstang's Avatar
Originally Posted by ZONES89RS
Gayness......
Why is that '' Gayness '' because there trying to be safe lmr cars are making way more power than Hinsons vette
Old 03-27-2011, 07:41 AM
  #125
5w20's Avatar
The camaro does make a bit more but the red corvette makes comparable numbers.
Old 03-27-2011, 07:44 AM
  #126
LS1TECH Sponsor
Bryan@LME's Avatar
I would a think a Bonneville car would be set up with a dry sump oil system. I would like to see one on any engine that is held at wot for any duration.
With this engine we will just have to see what happened. I assure you guys the clearances were triple checked and set up for its intended use & power level. I think we will find that there is an oil starvation issue or something else let go.
Old 03-27-2011, 08:00 AM
  #127
Moderator
BADZ's Avatar
I would give any shop the benefit of doubt until they go into it and find out what happend. LME along with most shops stand behind there work. If you are racing to a top speed "race car" anything can happen.
Old 03-27-2011, 08:35 AM
  #128
LSX-coupe's Avatar
I know Flaco is putting down comparable numbers through a 4l80. And he uses stock style oiling system. With no issues.
Old 03-27-2011, 08:38 AM
  #129
5w20's Avatar
Who built that engine?
Old 03-27-2011, 08:54 AM
  #130
Moderator
BADZ's Avatar
Flaco= HKE
Old 03-27-2011, 09:06 AM
  #131
ProStreet_632's Avatar
You guys just can't catch a break, bring the cars back in 1 piece and shoot for the next mile.
Old 03-27-2011, 09:16 AM
  #132
KCS
Moderator
KCS's Avatar
Has Flaco hit 200mph yet?
Old 03-27-2011, 10:14 AM
  #133
MY06TBSS's Avatar
The oiling issue is going to be because they are rear mount turbos......Flaco and Bise are front mount there is a huge difference in pushing oil from the front to the back and back to the front for the turbos at that speed and rpm!!!!= oil starvation.....HKE builds bomb proof engines if treated right....
Old 03-27-2011, 10:43 AM
  #134
KCS
Moderator
KCS's Avatar
Are you saying that there isn't enough oil to feed the turbos and the engine at the same time?
Old 03-27-2011, 10:57 AM
  #135
MY06TBSS's Avatar
I am saying with the forces placed on the oiling system under full acceleration the oil is having a hard time returning to the engine...
Old 03-27-2011, 11:07 AM
  #136
rickykline's Avatar
This may actually make sense.
Old 03-27-2011, 11:12 AM
  #137
MY06TBSS's Avatar
I have a tbss with twin rear mount 66's and am having the same problem....only i am only makin half the HP....
Old 03-27-2011, 12:01 PM
  #138
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
That isnt teh problem at all if they have a good return pump. A buddy of mine who posts on here as Casey2323 has a 106mm rear mount making well over 1000rwhp for about a year and a half, went 10 flat in a rcsb 99 silverado with only 1st and 3rd gear has had no problems at all with oil starvation due to running a rear mount. Running the stock truck oil pan(6qts) and a ported/shimmed factory oil pump. Something isnt right with your setup and I seriously doubt that is the problem with the LMR vette. Even if it is a build problem I doubt we will hear anything about it on the net like the past problems that have never been posted about...
Old 03-27-2011, 12:08 PM
  #139
MY06TBSS's Avatar
Single is one thing,,,,Twins is a whole different ballgame!!!!
Old 03-27-2011, 12:15 PM
  #140
1slow01Z71's Avatar
No its not, you either run dual pumps or Y in to a big single. There is a moderator ont he truck side with a 408 and twin rear mounts that was running just fine til he blew a oil pump fuse and toasted the motor but he didnt have any oil starvation problems due to the pumps not keeping up. What about the STS twin setup for the vettes, plenty of people running those with no problems.
