T/A 1996 LT1 overheating
the prestone does not congeal with the dexcool. its compatible with all colors of antifreeze, even orange ( dex cool). it'll only congeal with the old, what they call " conventional green" antifreeze. it sounds like you have water mixed with the oil, which is probably a head gasket
not too familiar with this, but from my understanding.. its an add on gauge where you put a probe somewhere in the engine and mount the gauge somewhere in the cabin to give an accurate reading of temperature if the original gauge is bad
ie.. http://www.revingtontr.com/shop/coll...pe=TR3&CID=792
Like someone else said... if your oil looks like chocolate milk (and smells kind of sweet) you have coolant getting into the oil.
i had this happen to me but my head gaskets are perfectly sound nothing wrong with them. I found about a gallon of water in my oil pan after i pegged my temp gauge to were it no longer works
so I pulled my heads to check to see if i had a blown gasket and they were good.
so now i have to have the block and heads checked.
hope this hasnt happened to you good luck
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
