Press Reluctor ring off and on
i need something along the same lines. i need my driveshaft center support bearing pressed off and the new one on. i asked my friend that works at a dealer and he asked the driveline guy and he said that he does not have a press big enough and would just use a pipe (i didnt like that idea) a local trans shop said a place called ct driveshafts could do it but i have not done any more searching since then. all i know is they are located somewhere in east houston or south east houston. good luck.
they (Reluctor rings) are easy to change, I use 2 large screw drivers and block of wood and "healed" them off, put them in the freezer for a cople on hours and they will drop on
BE SURE and look at how the rings go before removing them , there is a bevel side to them
Johnny
or CALL g-force in pearland
1941 County Road 129
Pearland, TX 77581-6246
(281) 993-5451
Johnny
(281) 993-5451
