Houston Area - Need someone to weld in rear end / install motor
Old 06-18-2011 | 08:25 AM
ModernMuseum's Avatar
Default Houston Area - Need someone to weld in rear end / install motor
I'm having some issues installing my LS3 into my 69 firebird. I've been jacking with it for several weekends in a row and can't afford to try to get this thing installed solo any more. I can almost get the motor in, but I think I may (worst case) need to get some custom solid mounts made.
Also, I need someone to align my rear end correctly and weld in the leave brackets to the rear end.
The Sugar Land area would be preferable, but I can haul it anywhere in the area as long as they're a solid shop. Thanks for any recommendations!
-Keith
Old 06-18-2011 | 09:30 AM
Gunrock_T/A_0811's Avatar
I kno G-force in pearland does conversions. It's going to cost you a lot. Might save some money by getting a welder to weld the rear
Old 06-18-2011 | 01:02 PM
Do they do good work? Everything is already set in place. Basically they'd just have to align everything, tack and weld away. For someone with experience, this part of the job wouldn't take more than 2 hours, I'd expect.
Old 06-18-2011 | 06:41 PM
Bad Chad's Avatar
You can buy motor mounts that will allow the motor to bolt right in.
Are you the person Phil called me about yesterday? I'm in Vegas and will be back tomorrow if you want to give me a call at 281-701-1909
Old 06-19-2011 | 07:58 AM
Hey Chad - yeah - I left you a voicemail on the number Phil gave me. I'll give you another ring today.
