delete
Old Jul 21, 2011 | 05:09 PM
skeeter99's Avatar
Default delete
delete
Old Jul 21, 2011 | 06:38 PM
LS1vazquez's Avatar
Umm... want a 1998 Lexus ES300?
Old Jul 21, 2011 | 06:55 PM
SSHAWK's Avatar
I have a 2006 trailmaster I'll trade for it lol
Old Jul 21, 2011 | 07:04 PM
skeeter99's Avatar
truck or sport bike only
Old Jul 21, 2011 | 07:05 PM
skeeter99's Avatar
You need to sell your turd and buy mine Sean
Old Jul 21, 2011 | 07:47 PM
SSHAWK's Avatar
lol Why would I want to buy a slower car??
Old Jul 21, 2011 | 08:41 PM
skeeter99's Avatar
Put ur heads on and well run title for title with my cam only motor well see who is slower lol
Old Jul 21, 2011 | 10:09 PM
kingd_202's Avatar
LOL if you win his car, I want his wheels and fast
Old Jul 21, 2011 | 11:20 PM
SSHAWK's Avatar
We already know this now!!!! lol So when do I get your title?
I like this guy already he even knows that I will beat you Josh lol hahaha.
Bump/
Hope you find a job so you don't have to sell or trade this car.
This thing.... is light as hell so anyone wanting a track toy this is a good start very nice car.
Old Jul 22, 2011 | 10:47 AM
skeeter99's Avatar
Bump/
You get my title when you buy ill do for 6000 for u lol You already know what this baby will do now!
Old Jul 23, 2011 | 05:45 PM
blown99bergerssclone's Avatar
Car:
1999 Camaro SS White t tops w/ rebuilt title. 177.xxx on car.
Motor, exhaust, fuel, & pcm:
2002 pcm and motor.
5000-6000 miles on motor!
stock 241 heads.
7.4 trick flow hardened push rods.
Trick flow .650 lift double springs.
Thunder racing Raptr cam 238/242 615/615 111
Ls2 timing chain
Melling high volume oil pump
Knick Williams 92mm tb
Fast 92mm intake (emblems shaved off and paintied gloss black)
FTP 98mm lid
LG bellow
FTRA ram air
Nitrous outlet single stage plate (nitrous kit sold)
Ls6 valley cover
Weapon R oil catch can
Asp 25% udp
Motivative soild motor mounts
Short belt mod no ac or ps
Bosch 42# injectors
Walbaro 255 w/ hot wire kit
Hooker long tubes (dont know size) was told 1 7/8
True duals with x pipe and bullets
Battery relocated to back
Optima red top
Tuned by Sam
Drivetrain, and wheels:
Fresh th350 has not even had fluid in it yet!
FMVB
Transgo shift kit
New clutches and steels
PTC 4500 converter 0 miles!
B&M extra large trans cooler
Energy poly trans mount
Hurst Quarter stick shifter
Stock 10 bolt with 3.73 gears
Brand new u joints 0 miles!
15x10 15x3.5 Racestar indistries wheels
Brand new radials in front (VW tires)
80% left MT 295/55/r15 on back
Suspension:
BMR cm tubular k member w/ motor mount stands
BMR cm upper and lower control arms
LG springs
Comp 3 way adjustable drag shocks in rear
Sub frame connectors
LG lca w/ umi weld in relocation brackets
SLP non adjustable boxed phb
Jegster tunnel mount tq arm
Interior:
Sunbelt light weight carpet
(1) Kirkey 17" hip seat
Auto meter tach, shift light, and trans temp gauge
This car weighs if i would guess 2700-2800 pounds. Its not a show car has metal cut out just about every where you can cut it. Has no ac. heat, or power steering. I dont Have accurate track times or dyno numbers because the 4l60e i had in it was **** and slipped no matter what was done to it. This car in good weather will run tens cam only easy. It went 11.4 with a blown tranny banging the rev limit and on bald drag radilas at 250 pounds heavier than it is now. With the th350 swap, the new converter, new drag radials and less weight it should be there. It still may need a good set of coil overs to set the suspension correctly. Im after a truck that looks good and only a truck. I dont care if it has any motor work but will not mind if it does. Id like it to be lowered and have some nice wheels or even bagged. Id like 7000 cash if no truck is available. May also consider trade for a sport bike r1, gsxr 1000, ect. I may keep the car im just trying to see if there are anyone interested in a trade for something i can dd and not have to worry bout get pulled over in. Ask as many questions as you want. It will need a hood and i will have more pics this weekend when i get it back together as of now its the car below in my sig this pic is w/o the lg springs that i am installing with new tubular front end!
2000 aprilia rsv Mille r fresh tags and inspection. Pm if interested
Old Jul 23, 2011 | 10:11 PM
skeeter99's Avatar
pm sent....Yall this car looks like an absolute beast with the new lowered stance i will try to get pics and video tomorrow
