Help headlight cleaning service
Old Aug 25, 2011 | 07:36 PM
blackdahlia1988's Avatar
Default Help headlight cleaning service
I need some one that has a mobile headlight cleaning service in Houston. anyone know of any or have their number my headlight I bearly visible at night, I would clean it my self but don't have the time.
Old Aug 25, 2011 | 08:26 PM
rabiddog's Avatar
This has to be a joke.
Old Aug 25, 2011 | 08:32 PM
texasglock23's Avatar
that post was helpful
I doubt there is a mobile cleaning service, but you can spend about an hour trying to clean them. I used wet/dry sand paper and turtle wax rubbing and polishing compound. A pad and orbital would be tons better, or the mothers ball and drill.
Old Aug 25, 2011 | 08:56 PM
Cam72aro's Avatar
You would be suprised there are many mobile headlight restoration companies in Houston.
Old Aug 25, 2011 | 10:19 PM
05 GSXR 1XXX's Avatar
Maguires makes a headlight polish, if that doesn't cut through it just use some high grit wet sand paper then use that polish. Real easy and won't take long at all
Old Aug 25, 2011 | 10:35 PM
Wow, didn't know there were any...but the results I have seen from detailers aren't much better than doing it yourself
Old Aug 25, 2011 | 10:37 PM
DopeFedZ's Avatar
http://www.clintsglass.com/
Old Aug 25, 2011 | 10:55 PM
Thanks for all the help guys I already had some ones business card but I thought I lost it, so thats why I was asking if any of you knew of anyone. I found it tho he does a really good job and he also painted my tail lights on my 08 g6. He does mobile services too. Heres his number if any of you need it. 832-752-0865 ask for Luis
Old Aug 25, 2011 | 11:33 PM
03Sssnake's Avatar
Old Aug 25, 2011 | 11:56 PM
94fixerTA's Avatar
Quick fix dot 3 brake fluid. Used it on an old 93 f350 that were terrible. Did a decent job but they were still yellow. Not sure of any long term drawbacks.
Old Aug 26, 2011 | 12:42 AM
jmurray87's Avatar
3M Kit from local auto parts store works great with wet sanding, also WD40 helps clear it up but if they are yellow/hazed will need sanding no doubt.
