trans cooler question/ what issues
i have a 4000 stall
i have a freaking gigantic cooler which measures 13x11.5x1.75 its a freaking notebook and it takes up almost half of the condensor.
i am also leaving all of the air deflector plastic stuff in place just to make sure the condenser and radiator can get all the air flow.
i am just concerned that the big trans cooler may take up too much space and cause some other cooling issues in this Texas heat.
thanks
Ed
i will figure it out thanks
I now have it mounted horizontally between the radiator support and a piece of angle running between the sway bar mounts with a 10" pusher on the bottom side. The cooler is 8" x 10" x 2" Mocal unit. With the cooler moved, it definitely receives a lot less cool air and when in stop and go traffic (rare), the head load from the radiator and engine bay just completely overwhelm the system and the temps rise up to the point where it was without a cooler at all.
I bought an LT1 radiator which I plan on installing either tonight or tomorrow and may move the oil cooler back in front of the condenser.
thinking about putting it somewhere else, but not sure where
i have a 4000 stall
thanks
Ed
are these temps on your stock guage? are you running your A/C?
