Why so many 5-120 wheels not enough 5-120.65 wheels
if you can size the tires overall height ( 24, 25, 26 inches tirerack and some of the manufactures sites have alot of info ) its an alternative way to see whats the biggest sidewall you can go. not all tires are the same height even if they are the same size(treads im guessing?). your rears on 18s should not be a problem unless your getting a unholy sidewall size or lowered. your front might need a smaller sidewall pending how wide you go and offset. was told up to 27" tires will fit ( new stock suspension ) but keep in mind the streets you drive on, how you drive and condition of you suspension I have 26.6"(H) 8.5"(W) +40mm offset fits under fenders perfectly, rides good but rubs on full steering lock... suspension is nowhere near new and streets are shitty.
