First Header Install...
Old Dec 16, 2011 | 08:12 AM
CHADsterss's Avatar
Default First Header Install...
Hey yall I'm doing my first LT header install this morning... I was wondering if yall have any tips before I dive into it?
Old Dec 16, 2011 | 08:15 AM
99 bad aSS's Avatar
be patient, expect to dedicate some time. Good luck.
Old Dec 16, 2011 | 08:37 AM
silverfox89's Avatar
Let us know how it goes? Santa is bringing me Lt's, so I'll be doing the same soon. Good Luck!
Old Dec 16, 2011 | 08:48 AM
SSHAWK's Avatar
What brand of LT headers?
Old Dec 16, 2011 | 09:44 AM
LeanPocket's Avatar
do it from underneith
Old Dec 16, 2011 | 09:55 AM
texas94z's Avatar
PB blast those exhaust manifold bolts.
Old Dec 16, 2011 | 10:18 AM
CHADsterss's Avatar
Victor series from edelbrock. If I pull the dipstick will I lose any oil?
Old Dec 16, 2011 | 10:29 AM
BadCompany VP WS6's Avatar
If you're doing it on the ground, jack the car up as high as you're jack will take it.
If you think it's high enough, it's not. You may want to add some 2x4's on top of the jack to allow the car to be jacked up high enough. The driver side header almost needs to go in vertically. Most importantly, be patient.
Old Dec 16, 2011 | 10:46 AM
CHADsterss's Avatar
Ok I answered my own question lol so how do I get the damn thing out?
Old Dec 16, 2011 | 10:50 AM
tvg001's Avatar
if im not mistaken you need to lift the car like 18 to 24 inches from the floor so jack up the car put the jack stands and then jack it up with 2x4 so u can raise it more you could also lift the motor a bit so it can be easier
Old Dec 16, 2011 | 10:57 AM
TINKRD's Avatar
the oil dipstick? there's 15mm bolt that holds it to the head. once thats off just pull up. it'll pop out of the oil pan.
Old Dec 16, 2011 | 11:03 AM
jbridwelltransam's Avatar
These people are right when they say Jack the car up HIGH! But be sure to use plenty of support for it, Jackstands on all four corners and Shake the car before you get under it. You will be wrestling with it a lot, and the last thing you want is for it to fall on you.
Old Dec 16, 2011 | 11:07 AM
TINKRD's Avatar
get a pair of dikes and cut a slot into the first and last header bolt hole on the gasket. when you get the header in place, loosely thread the 1st and last bolt. Then you can slide the header gasket in from the top. this method is 110% easier then trying to hold the gasket with one hand and the header with another while trying to align the header gasket, etc.
Old Dec 16, 2011 | 12:16 PM
prolly some of the best advice you can have right here!
Old Dec 16, 2011 | 01:09 PM
CHADsterss's Avatar
I've got gaskets from edelbrock... They came with the headers
Old Dec 16, 2011 | 01:16 PM
TINKRD's Avatar
if they're paper gaskets throw them in the trash. either re-use the factory MLS gasket or go to the dealership and get a new set.
Old Dec 16, 2011 | 01:17 PM
TINKRD's Avatar
i've been around a looooooooooooooong time negro. i dont mind giving newbies some helpful tips when it comes to easy stuff
Old Dec 16, 2011 | 01:21 PM
CHADsterss's Avatar
I appreciate the help I need some more advice. I'm trying to get these damned spark plug boots off on the passenger side and they aren't budging. We've got all of them off except #1, 5, & 7
Old Dec 16, 2011 | 01:24 PM
TINKRD's Avatar
factory ones are a bitch b/c of the metal heat shield they put them in. just dont pull on the wire itself! just try and grab the heat shield and wrestle it out.
Old Dec 16, 2011 | 01:29 PM
CHADsterss's Avatar
So it's okay if I leave the heat shield off the new boots?
