what size tires should i get? 18x9.5 wheels on a 2002 camaro?
i have seen a lot of different sizes used on 18x9.5 wheels and wondering what size i should be looking for for my camaro.
you could stagger them if you want but the 10mm difference between 265/275 is not much at all... if you keep them all the same size then you will be able to rotate them... if your wheels are all the same size i would keep the tire sizes all the same as well
