Backfire Help
Old Apr 17, 2012 | 08:30 PM
02beastly-byrd's Avatar
Default Backfire Help
Ok so if my car smells like gas an has been backfiring here lately in between shifts would that b signs of running rich? I'm just looking for some Info an I used the search button but I still felt like asking. Thanks
Old Apr 17, 2012 | 10:22 PM
Mike96z's Avatar
Engine light? If so its o2s, if not could be maf.
Old Apr 17, 2012 | 10:50 PM
ZERO's Avatar
Is it throwing any codes at all?
Old Apr 18, 2012 | 06:05 AM
No the engine light stays on. The O2s are bad I think also
Old Apr 18, 2012 | 08:23 AM
chrysler kid's Avatar
Bad 02's will mess up just about everything on the car. Order them online from amazon or rock auto they are about $32 for the good Denso brand
Old Apr 18, 2012 | 09:09 AM
I was told to buy some for an 02-04 Zo6 bc I have LTs an they say those read better at a longer distance
Old Apr 18, 2012 | 09:12 AM
TWS's Avatar
TWS
Pull the code. See if you lost a coil. Probably feels like it's down on power, huh?
Old Apr 18, 2012 | 09:27 AM
Greed4Speed's Avatar
You can buy the C5 rear O2's for the longer pigtail vs. extensions. Any other reasoning is speculation.
Old Apr 18, 2012 | 09:33 AM
TINKRD's Avatar
go to autozone and scan the codes.
Old Apr 18, 2012 | 10:06 AM
Mike96z's Avatar
Surely get them scanned, I bet it will be o2's. Driving on bad front o2's can really jack your car up. Been there, done that. If you already have LT's you already have extensions unless someone did a hack job on your existing ones which could be why they went bad in the first place. If you don't have extensions buy the longer ones, they are the same.
Old Apr 18, 2012 | 11:13 AM
Aggie_Ls1's Avatar
Does it backfire in between shifts at high rpms during WOT runs, or during normal driving?
Old Apr 18, 2012 | 02:17 PM
Ya going to autozone an gonna get the car scanned! Yes it doesn't feel the same for sure. So the o2s can b off a c5 doesn't have to b a Zo6? It does it during both normal and wot
Old Apr 18, 2012 | 03:31 PM
00pooterSS's Avatar
No they don't have to be off a Z06 all 4 of the sensors on the camaros and corvettes are all the same except the length of the wiring. The vette sensors have longer wires so you don't have to buy extensions or lengthen your current one's. If the 02's are really old it's good to replace them on any car because they get slow over time. But nobody here knows your problem and nobody can say with certainty the 02's will fix it so...
Get the codes then go from there.
Report back with codes before you go slapping parts on that the doofus at Autozone says you need.
I have a question, does your temperature gauge work? What temperature does it run at once it is warm?
Old Apr 18, 2012 | 07:48 PM
PooterSS- it runs at 210 when warm
Old Apr 19, 2012 | 12:45 PM
00pooterSS's Avatar
Okay, if the coolant temp sensor is bad it will run rich, sounds like it works.
Old Apr 19, 2012 | 12:51 PM
TINKRD's Avatar
Backfire on decel are lean pops
