Help with gasket choose
Old Jun 8, 2012 | 10:50 PM
slo89lx's Avatar
Default Help with gasket choose
So two different company told me two different gaskets to get for my stock ls2 with 317 heads to 9:5:1 compression, the is a turbo build project
The first guy said: Bore: 4.130 with a .060” thickness would yield an approximate compression ratio of 9.55:1. Bore: 4.130 and .070" thinkness will result in a slightly lower compression ratio of 9.36:1.
the second guy said It would require a .080 gasket which is really thick so we don't recommend it. , also, it would be custom
So which one would get me to my goal? thanks for your help
Old Jun 9, 2012 | 12:29 AM
NemeSS's Avatar
Ls9 gasket is around 4.1 bore .051 compressed.
Generally, prefer to keep gasket as thin as possible. Even with forced induction. Keeping the quench close to a .035-.040 area is known to be very beneficial for many reasons. In both n/a and forced induction engines.
The GM LS9 gasket is affordable,reliable and has proven great results so far.
Old Jun 9, 2012 | 03:54 AM
Bad Chad's Avatar
LS9 gasket is the way to go
Old Jun 9, 2012 | 04:01 AM
winters97gt's Avatar
+1. They work great on my car.
Old Jun 9, 2012 | 07:27 AM
slo89lx's Avatar
Sounds good thanks for the help
