Powder coat a Fast intake?
Old May 10, 2013 | 10:42 AM
droppedls1z's Avatar
Default Powder coat a Fast intake?
Just curious if anybody has powder coated a fast intake. I asked a few powder coaters and they said they haven't done any local and it being a composite material I was just wondering what if anybody has done it and how it has held up.
Old May 10, 2013 | 10:50 AM
BrntWS6's Avatar
Yes you can....I had mine done and it's held up very well. If you can't find anyone local a sponsor here "the powder pro" does them but there in IL.
I had mine done SOM....they had a match for it. He'll even shave off the letters if you want at no extra charge. I had them take off the FAST and leave the 92mm.
Old May 10, 2013 | 11:10 AM
Sweet I want to do a gunmetal grey! With red Fast letters!
Old May 10, 2013 | 11:53 AM
NastySSnTexas's Avatar
That looks bad ***! I have a new 102mm im about to put on and still not sure if im going to paint it, hydrodip it, or powdercoat. How much was this?
Old May 10, 2013 | 12:16 PM
BrntWS6's Avatar
^^ It was $200 but SOM is a premium paint. I think that was an extra $25.00.
Old May 10, 2013 | 12:35 PM
Somebody09's Avatar
looks ******* awesome!
Old May 13, 2013 | 12:31 AM
Luckymex_dallas's Avatar
Isnt grey with red letter close to its stock appearance?
That red one is.very nice.
Ive seen a couple coated, they look nice.
Also seem debadged and painted flat black
..to look stock intake.
Old May 13, 2013 | 06:38 AM
The stock color of the ntake is a variation of a grey but I want to paint it a charcoal gray to where it will be glossy and more appealing.
Old Aug 31, 2016 | 05:30 PM
themealonwheels's Avatar
Bumping this up...
PsychoSid and I have done two LS3 intake manifolds that both came out pretty nice. Both of them used powders that required 400DGF cure temps, but we just baked them longer at 375 IIRC. So, I know those will work.
I called FAST to ask if their material was the same as stock. No surprise, the tech said "I have no clue". So while I know we can powder GM manifolds with their MOC, does anyone know what the temp limit is for a FAST upper shell?
Old Aug 31, 2016 | 05:32 PM
To make up for the bump, here's one of the manifolds we did. It's in gunmetal pearl grey with a high gloss clear...
Attached Thumbnails Powder coat a Fast intake?-20160409_170401c.jpg   Powder coat a Fast intake?-20160413_175957c.jpg
Old Aug 31, 2016 | 09:50 PM
DopeFedZ's Avatar
That looks I may try coating a ls1 intake before I throw my ls6 in the oven. Are you preheating the intake and then spraying it while warm/hot?
Old Sep 1, 2016 | 06:47 AM
Yeah, the GM intakes are capable of withstanding the 375... we kind of use the off gas period as a preheat for a hot flock. On mine, we off gassed it for a couple hours because mine was used. The fumes were pretty bad lol! After off gas, we pull it and shoot a coat while its hot then do a partial cure before the next coat. We haven't had a problem with the ones we've done. The trick is deciding when it's done. For a powder that requires 10 min at 375, we will typically leave it in for 20-25 min at 375.
But for the fast? Not sure... if I knew it was the same material, piece of cake, 20 min at 375. But I don't know if the fast material has a lower melting point or not. Guess I'llhave to find out the hard way unless someone chimes in!
Old Sep 1, 2016 | 06:59 AM
DopeFedZ's Avatar
Maybe see if you can find a trashed one. i had a fast intake powder coated by the powder pro on here years ago. Not sure if he frequents the board but maybe you could try looking him up.
Old Sep 1, 2016 | 07:14 AM
Tuskyz28's Avatar
The hydrodipping deal is really cool... I've seen all kind of unique patterns hydrodipped.
Old Sep 1, 2016 | 09:16 AM
North*power's Avatar
I've been thinking about doing the hydrodip on my 102. Powder would probably last longer but I want it to be as close to chrome as possible. Spectra Chrome is also an option but I'm skeptical about longevity. The last thing I want to do is melt my $1500 Mamo ported intake!
Old Sep 1, 2016 | 09:25 AM
Tuskyz28's Avatar
I totally understand that!! I've seen all kind of patterns. Skulls, carbon fiber, money, snakeskin.... just to name a few.
Old Sep 1, 2016 | 09:37 AM
oscs's Avatar
Irrelevant but you can PC a water pump too. Just pull the easy seals off. The big one you can't get to can take the heat.
Old Sep 1, 2016 | 08:01 PM
DopeFedZ's Avatar
Old Sep 16, 2016 | 11:55 AM
A little update, the upper shell showed up and I put it on the back burner. I've taken to making custom Yeti/RTIC/Ozark cups for people, getting progressively more complex. That means more time on cups, less time for car projects.
I think I'm caught up on cup orders, so I've started sanding the shell. Plan is to finish sanding this evening and powder tomorrow. I'm aiming to do "Jack's Blue" with clear, and I'm debating an intermediate coat with a different color for the lettering. Maybe even multiple colors. Depends on where I end up, because I have a hard stop for the Texas game... Hook 'em!
P.S. I have two rules for cups: 1. No Alabama, 2. No OU (sucks)
Old Sep 17, 2016 | 01:48 PM
Got it done. I suspect the compressor at the shop is allowing trash, I'm not having this problem with the cups I've done at my house with another compressor.
