well got the bird back together but small problem
Old Jul 10, 2013 | 05:30 PM
scj's Avatar
scj
You may want to check the blinker fluid too.
Old Jul 10, 2013 | 09:06 PM
DarknessHunter's Avatar
yeah noticed my blinker fluid was low and I changed muffler bearings when I did the flux capacitor
Old Jul 11, 2013 | 02:10 PM
ok hooked the pressure gauge up and its at 55psi in run and during cranking it slowly drops so i checked the fuel pump relay, during cranking the fuel pump loses power. anyone seen this before
Old Jul 11, 2013 | 02:54 PM
imma_stocker's Avatar
Seen it happen with a low battery.
Running a single fuel pump or dual? Hotwire kit? Check the fuel pump relay, underhood fuse box next to A/C Compressor relay. Same relays so you can swap to check it works.
Old Jul 11, 2013 | 03:02 PM
2000 cammed ws6's Avatar
Check your crank sensor and oil pressure sensors. Helped a buddy of mine a couple of weeks ago with a motor swap on his ctsv and he had these connectors swapped and had the same type of problems. Good luck hope this helps
Old Jul 11, 2013 | 05:25 PM
my crank and oil sensors are 2 totally differnt shaped plugs but i did check to make sure map and cam plugs werent swapped. injectors open and coils fire but its still not starting, im in process of pulling front cover to make sure timing marks are lined properly
Old Jul 11, 2013 | 05:28 PM
and battery is really low got it on a charger right now
Old Jul 11, 2013 | 08:19 PM
well pulled the front cover off and timing was off by almost 90 degrees glad it didnt damage anything runs great now, also put new gas in
Old Jul 15, 2013 | 11:42 AM
Update?
Old Jul 15, 2013 | 10:31 PM
runs like a champ now its been raining past 2 days so only 20 miles on the new motor took it to walmart and back but lots of compliments there. gonna try and get another 30-40 miles in do another oil change and hopefully rain lets up soon so i can finish break in and enjoy it
Old Jul 15, 2013 | 10:46 PM
video of first fire up
https://www.facebook.com/photo.php?v...1830379&type=3
Old Jul 16, 2013 | 09:22 AM
  #32
Sweet
Old Jul 16, 2013 | 10:33 AM
  #33
thanks
