GM techs come in - I need help
Old Jul 8, 2013 | 08:17 PM
JoeKnowsBaseball's Avatar
Default GM techs come in - I need help
I have a friend who is trying to get through nursing school in this 2005 cobalt with a 2.2L ecotec. Long story short, it needed a motor. We found a decent priced one out of a 2007 Malibu and from what I had read, all those 2.2Ls were interchangeable.
I get the motor into the car and start hooking up the wiring harness and discover that this new motor has an extra camshaft sensor. No big deal. Then I find that the crank sensor on the old motor is a 2 wire hall effect sensor (which i believe only reads TDC) and the new motor uses a PWM 3 wire sensor reading a 36 tooth ring on the crankshaft. Obviously you can't use the old sensor on the new crank or vice versa. The car won't start and immediately throws a CKP code P0332 I believe.
Do any of you GM techs know what I have to do or what I can do to make this motor run?
Also, I just wanted to say that no good deed goes un punished. lol. This car has been nothing shy of a nighmare the whole way through and I just need to get her back in her car. Thanks in advance to anyone who can shed some light on this shitty situation lol.
Old Jul 9, 2013 | 01:38 AM
01WS6/tamu's Avatar
Man I hate to say it but you are screwed 9 ways from sunday after looking over diagrams and descriptions. The 07 motor uses a 58x crank sensor and trigger wheel on the crank. The old motor the 05 2.2 uses a 7x reluctor wheel and crank sensor.
Essentially it's like trying to put a 13' 6.2 into a 02 camaro it fit's and looks the same but that's where their likness' ends.
Sorry to be bearer of bad news but nothing you can do will ever make it start or run.
Old Jul 9, 2013 | 10:23 AM
ramairracer's Avatar
yup wont work, better off returning it
Old Jul 10, 2013 | 08:17 AM
We're past the time of returning the motor. At this point, it's sell this motor and buy a new one...
I considered ever swapping cranks over, but that seems like more work than putting a new motor in.
Old Jul 10, 2013 | 10:05 AM
What if I put a 2007 Malibu ECU in it and added the extra wires for the camshaft sensor, crankshaft sensor and 2 additional wires for the throttle body?
The harnesses should be the same other than those wires...
Old Jul 10, 2013 | 09:10 PM
01WS6/tamu's Avatar
Don't even think about it you'll really have a clusterscrew on your hands. There are too many modules that cross communicate and changing one of them throws everything out of whack.
Your biggest problem will come in the form of the passlock and databus communication issues due to incompatible pcm with other modules in the vehicle. The rolling codes programmed into the bcm and pcm change year to year so a 07 bcm will have antitheft codes from what the 05 pcm is looking for and you'll have a no start condition and DTC for.
The cam reluctor and sensor are different teeth counts also.
Change the motor don't start messing with electronics.
I have a very reputable salvage yard we have dealt with exclusively for years if you want pm me and I'll give you their number and they can get you a solid reliable engine at a great price. They are out of the austin area.
Old Jul 11, 2013 | 07:28 PM
99RedHawk's Avatar
What about changing the heads to the 05 , if the sensors are located on them and put your crank sensor into the 07 block?
