lq4 408 build help
Old Jan 14, 2014 | 12:59 AM
MAG1C's Avatar
Default lq4 408 build help
Sup fellas .well I got a 408 stroker that I am building mybfirst build so this is what is what I got so far
408 with 10.1 je pistons , bullet cam
317 P&P heads dual springs, stainless valves
....ok so my questions is this should I get l92 heads and nnbs intake or should I buy this 2.3 whipple supercharger they got for sale for $2500 since it will bolt up to the heads ....help me out fellas .thank you in advance for yalls help
Old Jan 14, 2014 | 07:02 AM
Greed4Speed's Avatar
Since you have the cam listed, what are the specs?
Are you willing to get a cam ground for L92 heads or a blower?
Old Jan 14, 2014 | 07:44 AM
jeremyfrank14's Avatar
l92s......
Old Jan 14, 2014 | 11:41 AM
Taspeed's Avatar
both
Old Jan 14, 2014 | 09:38 PM
MAG1C's Avatar
This is what the cam says
53R11013
2870H
This is what I came up with
232/238 .600/.612 111+1
Old Jan 15, 2014 | 04:59 AM
Not a blower friendly grind. Take that option off unless you're willing to switch. A SC will also require fuel system enhancements.
Old Jan 17, 2014 | 01:46 AM
MAG1C's Avatar
So should I stick with my p&p 317 heads or upgrade to the l92/ls3 heads? Also what size stall should I get for me 4l60e
Old Jan 17, 2014 | 07:49 AM
That depends on how your ported heads flow compared to the L92's. I personally wouldn't go through the hassle unless I was able to go upgrade to nice aftermarket castings.
I'd go straight to the source for converter info.
Old Jan 23, 2014 | 10:20 AM
MAG1C's Avatar
Ohhhh ok
Old Jan 27, 2014 | 04:24 PM
MAG1C's Avatar
Some guyvis selling me some ls3 heads milled 42 thousands what would that do to my motor?
