lq9 issue
Old Jan 26, 2014 | 11:12 AM
DarknessHunter's Avatar
Default lq9 issue
Ive got almost almost 3000 miles on rebuild and no issues till a few days ago after about 7 miles pressure dropped to about 25psi bounces and ticks at idle with throttle it goes back to normal. I got to school another mile down the road car sat for about 5 hrs, I started it up and no issues then right before I got home it started acting up again
Old Jan 26, 2014 | 11:43 AM
Pollo432's Avatar
Don't run it anymore. Pretty close to the same thing that happened to me. Kept running it to "test" it and spun 2 mains with 500 miles on rebuild. You drain the oil yet?
Old Jan 26, 2014 | 11:50 AM
shes in the drive way checked oil and its still looks fine no shavings or glitter
Old Jan 26, 2014 | 01:16 PM
FireHawk178's Avatar
My car has been doing this for years. Stock LS1 with ~155k miles. In my head, I've been blaming a bad/leaky pressure sender. Maybe it's just me hoping it's nothing more, but it hasn't changed with numerous oil changes of different weights, etc.
Old Jan 26, 2014 | 02:47 PM
low bounceing pressure at idle happened on my stock ls1 but nvr this low or big of a bounce its more the ticking that worries me
Old Jan 26, 2014 | 04:37 PM
Pollo432's Avatar
New oil pump? Was it shimmed correctly? Also my bro had a "tick" in his truck once. Tore down the engine. Did a cam/head swap new valve train. Still had the "tick" after. It was a bad 200k header gasket. Word of advise don't guess and start changing parts or "hoping" for the best. Do research and trouble shoot.
Old Jan 27, 2014 | 03:21 AM
01WS6/tamu's Avatar
Put a mechanical gauge to verify the problem. Then pull it out and start tearing it down and you just gotta do a post mortem on it one step at a time till you find the smoking gun. I had a 6.0 in my wifes truck spin a cam bearing and do almost exact same thing.
Old Jan 27, 2014 | 06:19 AM
A-Dub's Avatar
When that happened to me, I had the pressure drop, sounded normal at idle, ticked at 2k rpm. Rod bearing was toast. I had 5500 miles on my rebuild...
Old Jan 27, 2014 | 09:24 AM
loosened valve covers yesterday and let it run in driveway revving up every so often for 30 minutes and no noise no drop, ill try taking it for a drive later today before school
