Bent rod, Tuning the cause?
#61
This story sounds all too familiar. David I already told you everyone to use. I am positive that if you take my advice, you'll be hauling *** reliably. My LME engine and Chris Delgado tune are spot on perfect. Yes Pat G and Bad Chad do great work also! I will never get ripped off on Labor cost again because I've learned so much from my good friends Garrett Bennett and Bad Chad. I have been completely ripped off by 3 local shops and look for every opportunity to drag the **** out of their street cars. BTW you know who you are, say when and let's line up.....
#62
Never ask for tuning "advice" (aka whos fault) on this forum (much less any forum)... 98% of the people in this thread couldn't even setup a BS3 base map and it is full on retard easy.
Don't know the details (honestly tried to skim the thread but I realized why I don't post on this forum anymore) but **** happens doesn't matter if god himself tuned the car anything CAN and WILL happen at some point.
Khenry I still remember when your car showed up with that Kenjo kit. With the ProEFI I wouldn't let anyone besides Chris D. tune it so good choice.
#63
Just got off the phone with the OP and this will be another happy customer of LME, Bad Chad, and D3PE. Another Houston Camaro dragging other local shop's CTSVs and C7s. If you're starting a build PLEASE contact me on who to use and not to use in the Houston area, I will save you 10's of thousands of dollars and lots of heartache.
#64
#65
I've had the worst builds money could buy until I learned how to do it myself and get a tuner that cared so yes Chris Delgado gets this car and all of my future cars. Customer service is everything to me. LME and Chris Delgado (D3PE) are stand up companies that will handle your build like it was their own. The OP got bent over and what goes around comes around. When it's done this time he'll be able to call out any street car that shop builds in confidence just like I can. If any other local shop has a street car that wants to meet at the track or Mexico hit me up.
#66
Well since you are going with D3 now ask Chris how well he likes those ID injectors? You may not like the answer you hear and also explain why things happened.
I am in now way implying this story is a lie or anything like that. We've known each other since 2003/2004 and you've never lied about a thing. I also know it wasn't sure your intent for some of the other post that came along with it.
And a little something to think about you had a stock motor and power levels were high but not to high... Not every motor in the same car is created the same... If it was not an injector failure could have been something as a weaker factory part on the day your engine was assembled. My Porsche motor stock made 868rwhp and my brothers stock Porsche motor just made 898rwhp. Mine did for about 6k miles (4k being on race gas) and Matt's is still trucking along. Now if we took 20 Porsche motors and did the exact same setup and tune I bet maybe 5 would actually last more than a few dyno pulls. It's the only problem when dealing with factory engines. You can't be 100% sure that motor will be as strong as the next.
#67
I had Gforce build me an engine and fix my shitty Kenjo kit, the day I picked up the car and drove it home (45 miles) it had drank 1 gallon of water and 1 qt of oil. I called Robert/Mike as soon as I pulled in the garage and was told "that's the nature of the beast with a turbo car just keep an eye on it and top it off when need be." They refused to look at the car and I was told they had the wrong waste gate spring in when they made the first pull on the dyno by someone that worked there back then. So yes I got screwed and when I pulled the heads off there was a Crack between #5 and #7 cylinders. Long story short that IS NOT THE NATURA OF A TURBO CAR. I make over 1600whp with a good build and tune and my car drinks neither water or oil.
#68
Didn't know you broke the 1600rwhp marker! Car should go some high 7s @ 175-180mph without a problem! I doubt our 85mm 434ci SBF will make but about 1450-1500rwhp (on the dyno) and hope to run some 4.5X's with it and we have to weigh 3350. So at 1600+ at 3600lbs the car should be as close to the numbers our X275 should run.
#69
#70
I would have thought they would have pulled the injector when they had it to tell me it was the issue. That didn`t happen, so this points in a different direction correct?
#71
I run ID injectors in Matt's 997TT and I had them in my car when it was running on E85. There have been post on other forums where they have acted up and then were fine and some where it just failed. While installing my motor a year or two ago I actually had one that stuck closed. We fought for a few hours looking what was causing the misfire and I remembered I could fire each injector and coil under the ProEFI to test and sure enough we found our problem. It also made a LOUD boom a few times when I still had fuel in the cylinders I'd test the coil on.
It's not something most even think to ever look at it since it shouldn't be an issue. As I said things do happen that we don't likely expect. Unless they had experienced one fail there was no reason to check. It took us a few hours to figure it out because I had complete control of EVERYTHING ECU wise (no factory ECU involved). If it were still stock ECU I would have been screwed. Also its a platform that both my brother and I know like the back of our hands but even then had I not known how to test each injector it would have been days upon days of figuring it out.
#72
Regardless I hope for the best for you David I'm sure Khenry has you set up with the "right" people. You will be able to enjoy the car even after this set back.
But to me I will always continue to suggest G-Force when it comes to LSx based platforms in our area. But what do I know about building/owning anything fast?
#73
#75
mike or someone from gforce posted then the post vanished. everyone who gets email notifications of an update to the thread has an email of what was said.
#76
You mean KH car has been to just about every shop LOL! But I don't gauge anything on ONE car I built or the ONE experience I've had even if it's gone through multiple motors. I've built a lot of cars WAY more than the average person. And as much as some small shops. I have a good idea of how to build a car and who to use. All I will say is I don't think the shops that KH put you on to will save you any money. BUT they will probably build you a decent car. Bad Chad will definately save you some money, but he's the exception for the shops around the Houston area.
#77
#78
Yeah I usually recomend people that I have used, and that have done good work for me, not what someone else said. But hey I warned you that his place looked run down. But if you judge by apperance NP, then hope you found someone that made you happy. Plus if I recall you were looking for CHEAP! You didn't even USE him to know anything about him! So your opinion doesn't mean anything to me either! But hey anytime you want to compare cars. I'd like to see something YOU have actually built!
They're "competitively priced"
#79
#80
Your right about the upfront money being spent wisely for sure.
