Ignition and door key replacement
Old Apr 11, 2015 | 07:33 PM
ZONES89RS's Avatar
In-Zane Moderator
Default Ignition and door key replacement
Think I remember that you could take the title for the vin on a car to get keys made at the dealer right? My wife lost her keys and the trans am will sit till I get more made. Rather not swap ignitions and door keys if I don't have to.
Old Apr 11, 2015 | 08:33 PM
codyvette's Avatar
That is correct. Most dealers will take an insurance card as ownership verification. Just remember, if the VATS module has been changed by anyone over the years and didn't relay the message you are screwed. You will have to have a tuner turn off the VATS and just change the tumbler.
Old Apr 11, 2015 | 09:37 PM
ZONES89RS's Avatar
In-Zane Moderator
I have HP tuners, so wasn't worried about that. Why would I need to chance the cylinder if I turn it off? The BCM?
Old Apr 11, 2015 | 10:00 PM
codyvette's Avatar
No need to change the cylinder (tumbler) as long as the original key pattern is still with the car. I have ran across cars that still use the same key resistance and a different cut on the key.
Old Apr 12, 2015 | 01:17 AM
ZONES89RS's Avatar
In-Zane Moderator
You mentioned turning off vats and changing the tumbler. That's why I asked. If VATS is off it won't matter at all as far as I know.
Old Apr 12, 2015 | 08:44 AM
codyvette's Avatar
Just saying the VIN will provide the dealer with the original resistor code and the cut pattern.
Old Apr 12, 2015 | 11:41 AM
ZONES89RS's Avatar
In-Zane Moderator
I'll try them out tomorrow if we have not found the keys. Evidently they are the only keys lost in her key set that we don't happen to have a copy of.
Old Apr 13, 2015 | 12:44 PM
imma_stocker's Avatar
Ignition and key have to match cuts.
Computer and key chip have to match codes.
Two layers don't have to be original from showroom but car needs both to pass. One to turn the key and other to OK the crank signal.
Old Apr 13, 2015 | 05:40 PM
ZONES89RS's Avatar
In-Zane Moderator
Yes captain obvious, we know this. Lol
Update, just got back. Door key, perfect. Ignition.....works. Takes..... Negotiation. But it works.
Old Apr 13, 2015 | 08:39 PM
codyvette's Avatar
I hope you got more than one or you bookmark this thread. LOL A wire wheel will render that ignition key more friendly.
Old Apr 13, 2015 | 09:38 PM
ZONES89RS's Avatar
In-Zane Moderator
I already started working it down a little. It will be fine in time.
