nitrous question
Old Jul 23, 2016 | 11:30 AM
chrisLT1's Avatar
Default nitrous question
just installed my NX wet kit running it through the NX window switch (on @ 3000 off @ 5700) set on TPS and RPM I have set up my TPS mode in the settings and everything looks good but no spray I'm getting nitrous to the purge but nothing out of the N20 noid WTF! anyone had this problem I must be doing something wrong by the way the entire kit is only about a month old
Old Jul 24, 2016 | 08:55 PM
soloman369's Avatar
Make sure the kit works with the tps switch first .
Old Jul 26, 2016 | 11:00 AM
AJatNitrousOutlet's Avatar
There's a few different things that can cause that. What's your bottle pressure at? Also, have you verified your trigger voltage and grounds?
