Check Engine Light code question
Old Sep 22, 2016 | 06:20 PM
Charlie Hustle's Avatar
Default Check Engine Light code question
This may be a dumb question, but is there a difference between clearing a code, and deleting one? I had my father in law bring his scanner over and erase 1 code (running lean) and a couple of days later it the check engine light came back on. I was under the impression that once you removed or deleted a certain code, it would no longer cause the CEL to come back on. Can someone please enlighten me?
Thanks
Old Sep 22, 2016 | 06:40 PM
LSX Power Tuning's Avatar
If you just clear a code with a scanner it can come back. In order to permanently delete a code you have to run the tune out, delete the code in the pcm and reflash the new edited tune back in.
Old Sep 22, 2016 | 06:43 PM
Thank you for the info sir.
