High pitched whine
Old May 6, 2017 | 03:32 AM
Big bird55's Avatar
Default High pitched whine
I just had to replace an alternator on my car. I bought a new on and installed it and now I have a high pitched whine that increases with rpms. When the igniter is unplugged the whine is not there any thoughts?
Video is an example of how mine sounds also
Old May 6, 2017 | 11:01 PM
Big bird55's Avatar
No one?
Old May 7, 2017 | 06:24 AM
ZONES89RS's Avatar
In-Zane Moderator
Interesting. Make sure it isn't moving to a RPM where you are hearing a small leak from the PCV or anything.
Old May 7, 2017 | 02:58 PM
Big bird55's Avatar
Whine increases with rpm. No leaks found from pcv or anything.
Old May 8, 2017 | 07:08 AM
ZONES89RS's Avatar
In-Zane Moderator
If it was only after the new alternator, I would warranty that ****.
Old May 8, 2017 | 04:10 PM
II Fast's Avatar
Don't worry, sound's like your supercharger is working properly.
Old May 9, 2017 | 12:56 AM
Big bird55's Avatar
When the original alternator started making that noise and went out I was at the small tire nationals and had all kinds of people staring me down. Had one dude ask what blower I had on it...
Now I'm in the spot where I need to pull the engine that's in it and fix it or find a decent replacement motor to swap in since mine has dropped oil pressure, has excessive blow by and taps way to much. Can't do that however since I just paid finished paying last semesters college tuition and empty my bank account to do that. Hince why I have the for sale ad in the sale section trying to sell some of my other things.
Old Nov 30, 2017 | 11:28 PM
Luigi66369's Avatar
Did you resolve this problem?
Had the same thing happen to me. Original alternator started making high pitch whine, sounded like it was coming from audio speakers. Then my car died while I was driving. Had new alternator and battery installed. Whine still continues as soon as you start the car and then the sound gets louder as RPMs increase. Dealership basically shrugged their shoulders and said everything is working properly.
Old Dec 2, 2017 | 07:40 PM
Big bird55's Avatar
I have been through 3 new alternator and no solutions yet. Mine doesn't have a while that increases now it's just a consistent whine now.
Old Dec 13, 2017 | 08:28 AM
moekluse's Avatar
Pull off your belt and check any of the pulleys for play or bringing noises.
Old Dec 16, 2017 | 07:48 AM
jlrz28's Avatar
10 Second Fun Car
When you say new alternator, does that mean a "new" one from Autozone or Oreilys? If so I went through 3 of them in a month one time. Ended up taking it back and going to the dealership and buying one never had a problem again. Years later I replaced it with one of these that I have on the car now and its been good. https://www.summitracing.com/parts/p...t/model/camaro
Old Dec 18, 2017 | 02:10 PM
Big bird55's Avatar
Oriellys. I Was looking at doing the truck alternator but was worried about the wires garage and mounting it since I'm an iron block now. I drilled and tapped the mounting hole for the bracket but there is still 1 hole that isn't used on the block besides the mount on the back of the alternator
