Come help me build my rear! I got beer!
If your only doing bearings is pretty simple. Make sure you use the same bearing manufacturer, like Timken. Keep track of the shims and what side they come from. Make sure the bearings caps go back on the correct side and that the notch is pointing out. Take a picture of the diff before you start. Buy two crush sleeves just in case you *** one up.Make sure you put the pinion shim back on. Its really just paying attention.
