Formula Firehawk Build Thread
Old Jun 3, 2018 | 09:15 PM
Dr Tran's Avatar
Problem?
Default Formula Firehawk Build Thread
I figured I would finally get around to documenting the build of my Formula Firehawk.
I bought the car from a member on here in July of 2016 and was very happy with the car and only felt like changing a few things at first. Then the mod bug bit. Car already has full exhaust and was lowered with Koni double adjustables on all 4 corners so it was a good starting point for a build.
So then I decided to get rid of the high rise hatch and install the factory low rise after a repaint of that hatch and give it a nice full detail:
Old Jun 3, 2018 | 09:17 PM
Dr Tran's Avatar
Problem?
I swapped the silver wheels off the car for a while but I knew in the end I wanted some Fikse FM10's for the car and I found some locally for sale that I snagged up and decided to go with a custom center color with a custom center cap.
Old Jun 3, 2018 | 09:19 PM
one sweet ws6's Avatar
Nice car looks nice
Old Jun 3, 2018 | 09:25 PM
Dr Tran's Avatar
Problem?
I was slowly acquiring parts for a healthy NA 416 combo that consists of:
-K1 crank and rod rotating assembly with Mahle forged pistons
-Johnson link bar short travel slow leak down lifters to handle some serious RPM if it would be needed
-Custom TSP cam spec'ed by Elie at High Performance Consulting the "Mikehawk" cam
-PRC 247's with .700 lift springs that were then sent to Greg Good for a full port and valve job along with a cooling mod to help keep everything in check
-Greg Good Ported Fast 102 with Holley 102mm TB
-80lb DW injectors
Formula Firehawk Build Thread-kfdwtoo.jpg3
The motor then went to SAM tech to get some numbers and break in down on their engine dyno and it was found that the crank reluctor was pressed on incorrectly so the crank is currently back out and waiting on the new reluctor to show up.
Old Jun 4, 2018 | 09:07 PM
joeformula's Avatar
Lookin good
Old Jun 5, 2018 | 11:53 AM
blkbird's Avatar
Very nice. Glad you took the hi rise and put the Formula hatch back on. Hate when people do that to Formulas...... Great looking car.
Old Jun 5, 2018 | 12:13 PM
Dr Tran's Avatar
Problem?
Originally Posted by joeformula
Lookin good
Thanks
Yeah it just looks off without the rest of the TA body.
Old Jun 5, 2018 | 10:22 PM
Spd-Kilz's Avatar
I still have a boner.
Old Jun 6, 2018 | 11:14 AM
bluestreak98's Avatar
Lookin good!
Old Jun 7, 2018 | 12:41 PM
will69camaro's Avatar
Sex On Wheels
Can't wait for this to be fully together. Was a cool car before the 416, going to be AWESOME after.
Old Jun 7, 2018 | 05:56 PM
99WhiteKnight's Avatar
Cant wait to see the end result of this car. Well put together car.
Old Jun 17, 2018 | 06:25 AM
sway99bird's Avatar
Very Nice
Old Jun 18, 2018 | 10:17 AM
codyvette's Avatar
Thanks for doing something great with the car.
Old Jun 18, 2018 | 11:55 AM
Dr Tran's Avatar
Problem?
Originally Posted by bluestreak98
Lookin good!
Originally Posted by sway99bird
Very Nice
Thanks everyone. Reluctor wheel showed up, so im hoping to have the motor buttoned back up before the weekend then back to the dyno.
Old Aug 7, 2018 | 02:25 PM
blkbird's Avatar
Any updates/progress? Did you ever get it back on the dyno?
Old Aug 7, 2018 | 03:16 PM
LCTA's Avatar
Mean looking car, and looks like a solid build. That door looks like a mirror! Be careful of what you reflect.....never know what might show up Did you keep all the stock pieces you removed?
Old Aug 8, 2018 | 09:19 AM
Kenny D's Avatar
Watching!
Old Aug 8, 2018 | 11:34 AM
Dr Tran's Avatar
Problem?
It ended up spinning a rod bearing, so SAM is going through it to double check everything.
I kept all the stock pieces that cannot be replaced, or hard to replace.
Old Aug 8, 2018 | 02:54 PM
blkbird's Avatar
Well that sucks!
Old Aug 9, 2018 | 03:55 PM
joejamesatou's Avatar
That Borla exhaust has always been my favorite. Nice build.
