E85 Daily Driver?
Old Jan 21, 2019 | 01:55 PM
joejamesatou's Avatar
Default E85 Daily Driver?
Anyone here running E85 in their daily driver here in Texas? Aside from a fuel pump and bigger injectors it doesn't look to be that costly. I already have a 37 gallon fuel tank in it so range won't be too terrible. I'm thinking 20 hp or so gain given that I'm naturally aspirated.
Old Feb 3, 2019 | 06:02 PM
stoverz28's Avatar
I wouldn't do e85 on a daily driver due to availability. I have 3 local stations but when I take a road trip I never see them anywhere. My daily is flex fuel, rx7 is straight e85 and I can't ever take it out of town unless it's on a trailer.
That said, my tune (in the daily) adds a max of 8* of timing for e85. It's definitely noticeable.
Old Mar 11, 2019 | 05:23 PM
00pooterSS's Avatar
I do all day every day. But my truck was made to run e85.
What are you looking to know?
Old Mar 30, 2019 | 03:37 PM
Basically this... I have a 6.0 with about 10.8:1 compression. If I want to add a budget turbo to it I know that I'm looking at needing new heads to get lower compression if I stay gas. If I do a swap to E85 then I'm looking at keeping the existing heads. Or option 3 stay NA and do an E85 conversion with bigger fuel pump, injectors, and new tune. I just keep seeing these complete turbo kits under $4k and its so tempting.
Old Mar 31, 2019 | 08:37 PM
00pooterSS's Avatar
If you have e85 available in your area go for it. I love e85, averaged out with the loss of MPG the cost per mile is very close if not cheaper than running gasoline. So I get more power for the same cost. Have to fill up more often but that doesn't bother me at all. You can turbo 10.8:1 on gasoline all day too. It's been done many times. Need to have the tune dialed in but it absolutely can be done.
Old Apr 2, 2019 | 01:01 AM
RA032926's Avatar
you can also add meth for safety if you stay on 93 but it isn't needed on e85
Old Apr 2, 2019 | 03:27 PM
Thanks for the input guys. I forgot all about meth injection. Used to own an SRT-4 Neon and it was good for getting the stock turbo over 20 psi.
Old Apr 6, 2019 | 09:31 PM
hammdo's Avatar
I run both, e85 and meth. Plenty of e85 stations were I’m at in DFW area...
-Don
 Michael S. Palmer
Old Aug 15, 2019 | 01:38 PM
AnnivSS's Avatar
Im not sure what would be needed to do this on a Fbody, but I had dual tunes loaded on my evo with a switch in the glovebox. One was a low boost 91 octane tune and one was the full boost E85 tune. I drove it from OKC to Galveston and back on E85 without issue. Aside from 13mpg in a 4 cylinder lol.
Old Aug 15, 2019 | 05:41 PM
00pooterSS's Avatar
If you're on a stock cam now you could do a little bigger cam and lower you dynamic compression which would be a win win because you'd make more power at lower boost making it more efficient, cooler and safer due to all of that and due to lowering dynamic compression.
edit: just saw your signature. When contemplating which fuel you can run safely at what compression ratio the dynamic compression is what is important, with that cam you may have low enough dynamic compression already. Static compression of 10.8 with a stock cam can still be boosted, have to be careful but it can be done. Larger than stock cam usually lowers the dynamic compression, but not always. So talk to the person that made your cam or the person you are considering for a new cam and discuss the goals and they can tell you where you are now, or spec you a cam to get you where you want to be.
Heads is one way to get there, but the best cam for the setup is always a great plan.
