what is the difference between 18' and 23' degree heads?
http://www.trickflow.com/articles/18..._body_wlft.asp
Another big advantage of the 18 degree valve angle is valve location. The valves in a conventional 23 degree head are .275 in. from the cylinder bore centerline. When the valves are close to maximum lift, they become shrouded by the combustion chamber and the cylinder walls. That hurts the engine's ability to breathe--and that hurts horsepower.
The one drawback to 18 degree heads is that they can't use standard 23 degree head components. For example, the 18 degree head's intake manifold mounting flange is angled at five degrees (standard is 10 degrees) to accommodate the raised intake runners. That requires a special 18 degree intake.
The 18 degree heads are also taller than their 23 degree cousins, and require longer valves and special head studs. Eighteen degree pistons with domes and valve reliefs matched to the combustion chamber shape and valve locations are needed. And then there's the big kicker—18 degree heads must use shaft mount, offset rocker arms and mechanical roller cams with offset lifters. These components are readily available, but often cost more than 23 degree stuff. Nobody said going fast was gonna be cheap.
