Badbluess F.s.
This car has been my life since 2000.
I have had nothing but the best ls1 techs working on the car.
You can see video's of passes on HPE'S website,under media.
(Look for badbluess)
Will have pictures by this weekend of everything.
Best 1/8 Et. to date was a 5.82 @ 119 spinning.
Havent ran the car much 1/4 mile wise but one pass pilled at 300 went a 9.35 @129 letting out around the 900ft. area,and coasting.
So this car has consistent 8.9x's,and even faster,with the second kit,and a some weight loss.
Any questions feel free to give HPE call at 281-448-1300.
Thats where the car sits at.
BADBLUESS FOR SALE $27,000
PLEASE SERIOUS INQUIERES ONLY
LME BUILT 408ci. LONG BLOCK
-Wiesco nitrous pistons-
-Hell Fire rings-
-Lunati Pro Billet Connecting Rods-
-Clevite Rod Bearings-
-Federal Mogul Main Bearings-
-Lunati 4in. Crank-
-Comp R Lifters-
-Jessel SS Series Rockers-
-Stage 2 Heads Flowed 310cfm@..600 Lift-
-MTI Z1 Cam specs- 236/236-585/585-112 Lobe-
-Beck Sheet Metal Intake With NX SHARK NOZZLES Direct Port-
Also have a 2nd tnt dual nozzle nitrous kit which was never used but is on and ready.
ALL INFO ON THE NITROUS, AND FUEL MODS WILL BE POSTED AS I GET THEM, OR HPE CAN ANSWER IT FOR YOU.
EXHAUST COMPONENTS
-Kooks Stainless Steel 1 7/8”x 2”x 3.5” collector-
-Stainless Magna flow Oval mufflers-
TRANSKING SPORTSMAN GLIDE
-Pro Trans Brake-
-1.76 Factory Gear Set-
-Turbo Spline Hy-Tuff Input-
-Red Clutches And Kolean Steel-
-Steel Clutch Hub-
-Kevlar Band-
-Dual Ring Billet Servo-
-Needle Bearings And Teflon Seals-
-Jig Trimmed Factory Case-
-Deep Alum. Pan-
-Rated To Hold 1200hp-
-Circle D Nitrous Converter 4000rpm’s on The Brake-
-Drive Shaft Built by North West Drive Train-
STRANGE 9in. REAREND
-Full Spool-
-Strange 3.55, 3.73, 4.56 gears-
-35 Spline Axles-
-5/8” Wheel studs-
SUSPENSION
-BADZ Fully Adjustable Control Arms, and Panhard rod-
-BMR Extreme Duty Torque Arm-
-Wolfe Anti-Roll Bar-
-Hotchkis Subframe Connectors
-Hals Adjustable Shocks On All Four Corners-
-Hotchkis Drag Springs In The Rear-
CHASSIS
-6in. Mike Moran Prostock Hood-
-Certified Custom Built 10pt. Roll Cage-
-Cage Professionally Painted,Then Clear Coated -
THE PRO’S THAT BUILT THIS CAR
HPE, AND CREW
OUTLAW RACE CARS
I don't see how any of you guys could resist going all out down the track in these recently finished drag cars after all the hard work put into them.
quitters!
My car wont be even close to the mph these cars can do in a 1/4 mile.. But i sure as hell would give it a shot..
Now i do drive a couch on wheels... So maybe I have no clue...
Doesn't anyone drive their own vehicles anymore?
Ahh old times...
Seems to be an epidemic here on the Texas forum . But as for selling the car without ever driving it ....
