need an opti spark for 94 z
I believe my opti is going out, car takes to long to start and im getting alote of backfire, also when I checked the wires on the opti the opti opened up a bit. Well I need one in houston sealed,and good working condition
1 Post
I thought my Opti was going out this week also...turns out it was the ignition module. Before you jump to conclusions and say your Opti crapped out, you might want to start some troubleshooting. I took apart everything and cleaned the Opti reinstalled it and all and got the same results, but then I took my aftermarket ignition coil and module out of the ignition and went back to stock, everything works great now. Although now something in my idle control is failing...probably just the IAC hung open because I don't idle lower than 1500 now. Sheesh.
Mine had water in it and it had the same symptoms. I ran some air through the vent port and it fixed the problem, but I think yours is sealed so you will have to take it apart. Pull it off and take it apart anyway, you may be able to fix it w/o replacing it.
problem solved the opti was missing 3 screws and it was open and causeing a bad mis fire and also id had oil in there ? well i cleaned it up and selaed it good this time and car is running good now. thanks for help everyone.
