FS- "Built" 10 bolt rearend and BMR sway bar
This 10 bolt rearend has the aluminum T/A cover, girdle and stud kit. It has an Eaton HD posi unit, GM OEM 3.23 gears installed with the solid pinion spacer. The axle tubes have also been welded for added strength. All work was performed at Pyle Bros Racing in Baytown, Texas. This rear has held up to 1.43-1.45 60 fts. It is still currently in the car and quiet as a mouse. I built this rear to eliminate all the weak links that the 10 bolts are notorious for and it has proven to be very solid. It is a 4channel (ABS and TCS) rearend out of my 2001 Camaro SS.
I also have the (red) BMR 21 mm rear sway bar with poly bushings available as well.
I prefer local sales to prevent having to deal with shipping hassles, but it can be arranged.
10 bolt- $1000.00
BMR sway bar-$120.00 -Sold
Bowhunter1@ev1.net
Cell#281-705-0989
James
10 bolt- $1000.00
Bowhunter1@ev1.net
Cell#281-705-0989
James
