402 or 408
402 or 408
which one would you choose and be better for n/a setup?? trying to decide but keep going back and forth... just not sure about the ls2 becuase of all the re-wireing and moving everything... just wanted some other thoughts on this...thanks, dwayne
ls2 for na , lighter block and close to the same displacement . The lightness of the ls2 block makes up the difference .
The 408 iron makes some serious power & if you ever wanted to go with a power adder later the iron could take as much as you could throw at it .
There , this should confuse you a little more . Sorry
I went with an iron block BTW.
