problem with car
Old Feb 10, 2005 | 01:57 PM
Clif19's Avatar
Default problem with car
When i have the clutch pedal pressed in, it makes this ticking noise. When i start to pull it off right before im about to go into gear, the noise gets louder. Its a pretty quiet noise because i can't hear it over my music, only when its silent in the car can i hear it. I'm going to get the clutch assembly all replaced when my income tax check comes in, do you think it could be with the clutch or something else. Thanks for your help
Old Feb 10, 2005 | 03:02 PM
Clif19's Avatar
now my ******* car wont even go into gear, it was working fine earlier, im ******* pissed right now. I didn't want to have to get the clutch installed yet, but i might have to borrow money from my mom.
Old Feb 11, 2005 | 01:54 AM
LS1 CRAZY's Avatar
Default Ticking noise
Sounds like the throw-out bearing on your clutch is going.
Old Feb 11, 2005 | 07:04 AM
Spazdout's Avatar
Ginger Hater
theres a couple things that could be happening, it could be all the things listed above, and it can also be your pilot bearing.
Old Feb 11, 2005 | 09:10 AM
AAron's Avatar
you most likely have a leak somewhere. master, slave, one of the lines, or throw out. check your fluid level.
Old Feb 11, 2005 | 09:51 AM
Sprayed1998's Avatar
The noise was most likely your TOB, but it sounds like you need a new clutch at this point.
Old Feb 11, 2005 | 10:26 AM
| Powered by Satan |'s Avatar
Old Feb 11, 2005 | 04:01 PM
TheBlurLS1's Avatar
That's what she said...
make sure you get a new 01+ slave cylinder with that new clutch, it should come with a new throwout bearing already on it might also want to do the drill mod
the z06 clutch kit from SDPC.com isnt very expensive and it also comes with a new flywheel
Old Feb 11, 2005 | 09:40 PM
Clif19's Avatar
yeah im going to go to Icon Autosports to get it all installed. Most likely i'll call tomorrow and set something up.
Old Feb 12, 2005 | 01:13 PM
1 Bad Z's Avatar
See you Tuesday Clifton! Don't worry, T/A will be back on the road in no time
