Whats wrong with my car!!
Old Mar 2, 2005 | 07:11 PM
RGV_Z28's Avatar
Default Whats wrong with my car!!
I just installed a new cam, crank pulley, larger alternator pulley about 2 days ago I understand that a cars idle will be rougher than normal for about 100 to 200 miles until the cam learns itself, but is it supposed to turn off on you? My car is turning off whenever the gas is not pressed down, even when I'm on the expressway and I put it in neutral the car seems to die. I just got a brand new (red) optima battery and it still seems to die when I'm at a complete stop, while driving and the car is in neutral, or whenever I'm not pressing on the gas. Any suggestions?
Old Mar 2, 2005 | 07:26 PM
INVISIBLEZ's Avatar
Has the car been tuned?? I'm guessing not. Did you drill the hole in the throttle body blade bigger?? There are alot of reasons the car will not hold an idle, but the t.b. trick usually takes car of it. If you have not drilled the t.b. blade use a 13/16's drill bit to perform the task and chamfer it with a 1/4 drill bit.
Old Mar 2, 2005 | 08:34 PM
Bad Blu Formula's Avatar
Yeah, you need a tune because with out it, you car won't idle worth a crap, on or off the throttle. A tune will take care of the low rpm air intake to keep your car alive and well.
Old Mar 2, 2005 | 09:18 PM
02Z28LS1's Avatar
just an observation here, but how does a car idle while on the throttle?
Old Mar 2, 2005 | 10:09 PM
WillieD's Avatar
The cam will not learn itself into idleing better. You definately need to get a full tune on your car if you want to drive it around regularly.
Old Mar 2, 2005 | 10:40 PM
Krab's Avatar
Yep. Mine used to shut down after a WOT run when I was hitting the brakes. It really sucked, but runs just fine now after the tune. Tuning is crucial to get your car running right.
Old Mar 2, 2005 | 10:59 PM
RGV_Z28's Avatar
Well i have the predator and i advanced the spark +1 and the power enrichment +2 and at least now it idles by itself. I am going to get it tuned by a professional in a week or two. Anyone have any suggestions on the tuning??
Old Mar 3, 2005 | 12:25 AM
Redline2000SS's Avatar
yeah take your predetor with you when you get it tuned so they can take out the program and get ls1 edit and tell them to check your throttle body hole.
