gaugeing intrest on my 2000 camaro ss
Hey guys want to sell my car in texas so heres what its got. Its a black ss with about 50,000 miles on the odmeter. The car has a ultra z hood,hotchkis panhard bar,control arms,sub-frame connecters. Also has a moser 12 bolt rearend with 4:10 gears,33 spline axles and the hevy duty rearend cover. Also a inland empire driveshaft aluminum,and a extreme duty torqe arm from bmr. As for the motor my motor is a 382 all bore with lunati pistons and rods with stock crank. Has the R1 cam from mti. The heads have been fully ported and polished the heads are ls1 heads. The heads and block where done by pecos and bryan. This motor has about 1100 miles on it. The car also has a brand new T-56 transmission with a brand new stage 3 spec clutch and billit steel flywheel with a pro 5.0 shifter. Also powerslot brake rotors all the way around. I would like to get 14,000 for my car thanks chris.
P.S. No i will not part it out and if you are intrested in the car pm me with a # thank you
Originally Posted by JackZ28
Perfect timing, eh X? Only it's not a '98-'99. Did you at least keep the SS hood?
