The Drivers Edge
Brian
I had a great time at TWS and thought that the day went smoothly IMO. I will go to another track event in the future and most likely using DE.
www.frrax.com
Both are links that will help you out. I plan on open tracking the car this summer and would love to have another LS1 from houston accompany me.
www.frrax.com
I will check out the other links.
Brian
It's wide open, the track is wide and you can see very well.
At TWS, there are a couple turns that can get you into trouble and make for a really bad day.
But, of the 2, TWS is by far the fastest ...
mitchntx - it is my understanding that you have Bilstein HD's. What springs are you using ? I am going to get a 35mm front swaybar soon to help this plowmaster out.
Brian
Going up to a bigger bar in front will make it plow worse.
You need to either get stiffer rear springs or a bigger rear bar.
If you chose TWS ... T2 and T7 will reach out and bite your *** ... be careful ...
