help..Whats wrong with my Z06??
Old May 15, 2005 | 09:12 PM
sc300's Avatar
Default help..Whats wrong with my Z06??
i let a freind of mine borrow the Z06 last night and now 6th gear is gone..the gear box is very notchy and i have a hard time getting into all the gears..i can get into 6th, but the rmp just goes up as i give it gas..(like a slipping cluthc, but all the lower gears are OK)..
also the 1st to 4th light doesnt work and that im not forced into 4th from first anymore..
i think my freind was kinda drunk and was forcing into 2nd from first under slow acceleration and fucked something up..
any sugesstion?? and thanks in advance..
duy
Old May 15, 2005 | 09:15 PM
redaddiction's Avatar
Time to tell your friend he owes you some money to fix the cluthc/trans.
It is possible he messed up the synchro's
Old May 15, 2005 | 09:18 PM
99BLACKBIRD's Avatar
duy
I think our Z is just pissed at youfor letting your drunk friend borrow her. Sounds to me like your synchros are screwed. Possibly your clutch also.
Old May 15, 2005 | 09:45 PM
02Z28LS1's Avatar
wow, if i owned a Z06, there's no way in ******* HELL i'd let someone drunk (friend or not) drive it. i'd have a hard time letting anyone drive it anyway, especially with me not being there at the time.....
i do think it's time to tell your friend to fess up to what he did to screw it up
Old May 15, 2005 | 09:53 PM
JackZ28's Avatar
That's what you get for making a stupid choice.
Old May 15, 2005 | 09:55 PM
ChaoSS's Avatar
To do list
1. whoop friend's ***
2. fix tranny
3. repeat step 1
that sucks about your car man
Old May 15, 2005 | 09:59 PM
01ArcticSS's Avatar
Check the rear tires....probably bald if they weren't before.
Some friend...
Things you DO NOT loan out
Boat
Car
Dog
Wife
You pick the order.
Old May 15, 2005 | 10:08 PM
al's Avatar
al
It dosen`t pop out of 6th when you disengage the clutch dose it? But the notchy feeling sounds like syncros and or bent shift forks. See if he will confess to speed shifting the car and missing gears or grinding them. If he tried to shift without the clutch "properly" disengauged he most likley bent some forks and grinded some syncros.
Old May 15, 2005 | 10:10 PM
Your "friend" will probally now disappear after he finds out how much this costs.
Old May 15, 2005 | 10:16 PM
slowpoke96z28's Avatar
the transmission will need to be pulled apart and look for bent shift forks and destroyed shift fork buskings, or find a salvage yard that deals in newer vettes and get a transmission out of one of those. also, the clutch disc may be warped. this sucks, noway around that.
Old May 15, 2005 | 10:43 PM
02Z28LS1's Avatar
regardless of what's wrong, it's time to collect some cash or an ***-whooping....
a true friend would have come to you and said, "i screwed up your tranny, i'll pay for the damage if it's not covered under warranty"
Old May 15, 2005 | 10:59 PM
INVISIBLEZ's Avatar
Sounds familiar Duy, we broke tranny in the G-Force shop vette @ the track Friday. The problem was due to speed shifting it. The car got jammed in fourth, Jay had to kick the shifter to get it out of gear, first through fourth is gone. It won't go into 5th or 6th.
Old May 15, 2005 | 11:02 PM
G-Z06's Avatar
duy
It should be still under warrenty (03 right/Stock?) If so go take it to the dealer, get it fixed under warrenty. And let us know what the problem was bro.
Cheers
G
5w20's Avatar
notchy gears is either a fuxOred clutch or bent **** forks
Old May 15, 2005 | 11:24 PM
FIREHAWK #07's Avatar
with friends like that, who needs enemies
Old May 15, 2005 | 11:25 PM
5w20's Avatar
fuggetboutit
Old May 15, 2005 | 11:41 PM
regorih383's Avatar
Remember, **** happens. If you both are good friends, he should give you the money to fix it, or at least blow up his tranny in what ever he drive.....EYE FOR AN EYE
Old May 16, 2005 | 12:09 AM
5w20's Avatar
i dont know you....pay me for my alignment which didnt last you an hour after you checked to see if the curb was there....AND it was
Old May 16, 2005 | 12:42 AM
sc300's Avatar
****..this ******* suckssssss..i have kept this car stock for fear that something will break and i let someone use it one night and its broken...Now i got three cars with broken trannies at the same time..my supra, my nissan 240, and now the Z06...
this guy works for me so when i find out how much its going to cost me to fix it, im just going to have to deduct it out of his paycheck..
Old May 16, 2005 | 12:53 AM
02Z28LS1's Avatar
...this guy works for me so when i find out how much its going to cost me to fix it, im just going to have to deduct it out of his paycheck..
hahaha!!!!
