Old Apr 28, 2016, 06:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Noob Question, How To Reset Ecu?
Old Jun 7, 2005 | 05:17 PM
240M3SRT's Avatar
Default Noob Question, How To Reset Ecu?
Can someone tell me the proper way to reset our ecu. Usually i just unplug the negative for 5-10 min, but is there a better way? Im trying to erase the EGR code that came from me going to the ls6 non egr intake. When i put the egr thing back on the code went away but then came back. Runs fine its just anoying.
Old Jun 7, 2005 | 06:27 PM
240M3SRT's Avatar
Anyone?
Old Jun 7, 2005 | 06:33 PM
slowpoke96z28's Avatar
do that or remove the PCM fuse
Old Jun 7, 2005 | 06:37 PM
CRAGER's Avatar
Administrator
"do that AND remove the PCM fuse" That works on all cars (OBDII), when you disconnect the battery and remove the PCM fuse.
That should do the trick, but if the SES light keeps coming back on get it scanned and see what code it is throwing.
Peace,
Craig.
Old Jun 7, 2005 | 06:46 PM
240M3SRT's Avatar
Thanks guys.
Old Jun 7, 2005 | 10:43 PM
CySevans's Avatar
You don't have to disconnect the battery. Turn the key to the on position but don't start the car, pull the PCM BAT and PCM IGN fuses (in that order) in the under-hood fuse box, let it sit for five minutes, shut the key off, replace the fuses in reverse order, and you're done. Did it to my Trans Am many times.
Old Jun 7, 2005 | 10:46 PM
240M3SRT's Avatar
Mellow Yellow told me this to but i didnt know about the turning the key thing. Thanks.
