Ignition Auxiliary Power Position
In a Camaro, which way do you turn the key to get auxiliary power? I know this is a very basic and very ignorant question but I can not turn my ignition switch toward me. I just had my Z serviced and I told them about it and they said they would look at it. Well they looked at it twice (on two different ocassions) and changed the locking mechanism once and it still doesn't go to that position. It went into that position once, right after I got the car, and then I couldn't get it to lock into that position. Please tell me that I am dumb
or that the techs at the dealership are extremely dumb
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by rayosequis
You turn it back towards you, opposite of the way that you turn it to start it. Not sure what exactly could be wrong with yours, but you may try pushing the key in, and working it back and forth to see if you can make it go.
Man I worked that thing back and forth about 10 times right in front of the service manager and he said, "Okay, I'll get one of my service techs to work on it". Yeah they worked on it and replaced the locking mechanism and cut me two new keys and it still doesn't work. I should have tried it both times right after they gave me the car back at the dealership but I was late for work.
Thanks for the replies. I finally got it to work after my wife and I sat in my car and just starred at it for a few minutes and then started to twist away. I have to carefully push the button in and gently rotate the switch toward me and let go of the button and then kinda give it some pressure before it finally locks into place. What a mess!
