Coolent problem.!!
Old Jun 11, 2005 | 01:36 PM
Pewter02TA's Avatar
Breakfast Fanatic
Default Coolent problem.!!
This has only happend twice, but about 4 weeks ago i noticed that my car leaked some coolent in my garage and didnt really think anything of it, so i popped my hood just to check it out, and i noticed i belt was all chewed up but it still ran with it just like fraded alot. Then i took it to beck and masten because its still under warrenty and they said they checked everthing out and realinged the belt and that everything else was ok. So then i havent had any problems till i went to work today and came back home and in my garage there was a alot more coolent all over the place...... but its not ever heating or anything but its hot as **** out side and it only happend after the car sits a few hours.
Any ideas? And it is still under warrenty a few more months!
Old Jun 11, 2005 | 01:59 PM
CRAGER's Avatar
Administrator
"...realinged the belt..." WTF is that?
Do you have a TB bypass? I have seen people with that mod and it was hitting the waterpump pulley.
Just check out all of your coolant lines and try to find where it is coming from.
Take it back there and bitch again, and try to find the problem yourself and tell them what it is.
Good luck,
Craig.
Old Jun 11, 2005 | 02:00 PM
txhorns281's Avatar
yes, i'd say pop the hood and look for coolant leaks around the water pump and associated hoses. If it's leaking, it's gotta be coming from somewhere... Find that somwhere and there's your problem
Old Jun 11, 2005 | 02:38 PM
DONAIMIAN's Avatar
make sure the petcock is closed all the way since you said its comming from the passenger side.
Old Jun 11, 2005 | 02:47 PM
SLPformula's Avatar
If your overflow tank is too full or your system has to much coolant(or water) it will come out of the overflow after its been running at operating temp, the motor keeps the coolant cool while its on when you turn it off its starts to boil and flow over into the overflow tank and if its to full or your system is too full it wil leak out of the overflow tank thats prolly why you see it after youve parked it awhile.
Old Jun 11, 2005 | 03:45 PM
01 Red WS6's Avatar
I had a coolent leak and I never could find where it was coming from. Once I got it on the lift I found it would leak just a tiny bit from the water pump. When I replaced the pump I never had another problem. Maybe the bearings in the pump are shot and it causes the pulley to move around which causes the belt to be chewed up? I've never seen it happen on an Fbody but hey you never know. I'm just throwing out ideas
Old Jun 11, 2005 | 03:54 PM
FIREHAWK #07's Avatar
my friends Z would leave small amounts of coolant in his garage floor, he always thought it was from the AC, but after closer inspection it was from the water pump....
Old Jun 11, 2005 | 05:01 PM
Saad06's Avatar
exactly what i was thinking.
Old Jun 13, 2005 | 12:20 AM
Pewter02TA's Avatar
Breakfast Fanatic
Alright guy thanks for the info, im gonna try out a few more things....
Old Jun 13, 2005 | 01:10 AM
bluestreak98's Avatar
If you put a cam in i heard the leaking will stop.
Old Jun 13, 2005 | 01:16 AM
LS1 Brent's Avatar
Old Jun 13, 2005 | 01:43 AM
DONAIMIAN's Avatar
I heard the same thing, that ****** legit.
Old Jun 13, 2005 | 06:46 AM
platniumta's Avatar
Restricted User
Default coolant leak
Try to check the water pump, coolant overflow tank and the hoses. If it's still under warranty take it back and get them to fix it. Hope everything works out.
Old Jun 13, 2005 | 12:25 PM
Pewter02TA's Avatar
Breakfast Fanatic
I herd stangkiller is gay
Old Jun 14, 2005 | 12:42 PM
Bad Blu Formula's Avatar
Change the radiator cap.
