Good exhaust shops in tomball?
So does anyone know of a good shop that will be able to tuck my y-pipe up better and install the springs along with re-alligning the car for cheap with yet high quality?
281-290-8899
Vernon
Vernon
I went to get my truck aligned at All Star M&B I'm pretty sure they gave me the run around they said i needed $600 in work because i needed new tie rod ends and ball joints funny thing is the ball joints only have 10k miles on them. And this is what happend because i assume they did a half *** job putting it back together bc i told them i didnt want the wok done . Im came very close to destroying my truck and hurting or killing myself. I was doing 70 on the highway when i assume the nut came off. The only reason i didnt wreck is because the truck is lowered and the sway bar stopped it from coming all the way out. I knew something broke but i was in complete shock when i jacked it up and saw the nut gone.
Notice something very important missing also you can see where the tie rod hit the sway bar where they run by each other. They messed with alot of stuff when they had it i mean look how loose the saw bar endlinks are. I have no clue why they even touched those.
Hey madman can you do all of the things I listed? Y-pipe tuck, spring install, and re-allignment?
