blinker problem
Old Jul 27, 2005 | 08:19 PM
fastflames's Avatar
Default blinker problem
Anyone having a problem w/ the blinker lights going out constantly. With the rain we've been having it seems like I have a short somewhere. My lights inside and out are dimming badly without a stereo system. I took it to MTI and they couldn't figure it out, but my ignition relay keeps going bad. Someone please shed some light on this.
TIA,
Joe
Old Jul 27, 2005 | 08:25 PM
2 SLOW's Avatar
maybe some blinker fluid needs to be added?
camarodave98's Avatar
I had the same issue, every three days 1 would go out. Still havnt solved the problem, just took them out untill I can find a fix. I think water may have gotten in the socket and ruined it. Im going to get new sockets from GM and see if that helps. If you figure it out shoot me a PM.
David
Old Jul 27, 2005 | 09:19 PM
stevensLS1's Avatar
David
i had the same problem my blinker light (driver side) would go out like every few wks. well i finally repalced the socket and fixed the problem .. good luck guys..
Old Jul 27, 2005 | 09:35 PM
Brandon Boomhauer's Avatar
i put some dielectric grease in mine adn solved the problem
word of advice, if you replace the socket, autozone sells one significantly cheaper I do believe..
factory is like 85 bucks or something
Old Jul 27, 2005 | 10:05 PM
Greed4Speed's Avatar
You need to seal the socket. Mine did this, and I ran a silicone bead around the socket, let it get tacky then installed it. Never had the prob again.
Old Jul 27, 2005 | 10:06 PM
LS69TA's Avatar
Mine went out a few days ago after going thru a drive-thru carwash. Shorted out the bulb and the socket looks a little burnt, but I put a new bulb in and it's working so far. Brandon,any idea on the price of the socket from Vatozone?
Old Jul 27, 2005 | 10:46 PM
DONAIMIAN's Avatar
both of mine have been gone for damn near a year now, I dont care, I live in houston no need to turn signals.
Old Jul 27, 2005 | 10:49 PM
Parker TX's Avatar
Dielectric grease!
Old Jul 27, 2005 | 10:51 PM
fastflames's Avatar
thanks. appreciate the info. i will try new sockets and dielectric grease, then seal them.
