2002 Grand Prix problem, need help.
Someone else suggested it could be the cat, any way to verify its clogged or not? If it is, any way to declog it or would it need a new one? How do they get clogged anyway?
)I usually get the car going on a straightaway and floor it and see if the vacuum drops to zero and stays there. If it does then unbolt the exhaust at the y-pipe and test drive. Should have a big diffrence in power. If your vacuum hovers around 2-4in under acceleration then your problem is elsewhere. Good luck...
I had my mother put in fuel injector cleaner for 2 tanks, but still no better. The idle is fine by the way, any more ideas?
