Converted back to a LS1!
Should see me more often over here. I post on DFWStangs when I had the Bucket & Christine. But now they are both gone & a LS1 sits in their place.
Picked it up for $10,400
2000 Black Pontiac Formula with Black Cloth Interior 103,000 miles
Mods
Hooker Longtubes
Texas Speed True Dual X-pipe with Bullet mufflers. (VERY LOUD)
LS6 Intake
42lb Injectors
Yank 4200 Converter
3.73 Gear with T/A Rear Girdle
Thunder Racing Cam 598 Intake 598 Exhaust 110 Lobe Sep 231 Duration on Intake & Exhaust
150 Dry Shot basic kit
Eibach Pro Kit
Slotted Rotors
Stealth 10inch Sub
Carbon Fiber Lid. (LID IS CRACKED & NEED A NEW ONE
Some of you might have seen the car on LS1Tech.com. It was for sale for along time. Till I bought it.
Car sit's on 17inch Torqe Thrust II rims all around that have been Powder coated black Car has a Ram Air hood....
PICS of my New BABY https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/431931-11k-2000-formula-500rwhp-must-sell.html
!? that must lope hard as hell. Hows is the drivability with that? now you gotta get some 1/4 track times and dyno numbers.
Need to get the car tuned for here in Texas. The guy I bought it from was from New Mexico & the Elevation is 4200 feet there, Here in Dallas it is 600 feet. So once I get the tune down & get the valvetrain fixed. I will head out to the track.
I am very happy.Car needs some work on the trans. Doesn't feel like the converter is locking up when it should for cruising. When I punch it the car goes. But just cruising it seems like is rpms really high at 3200 rpms at 65mph. The 1-2 shift feels strong. But on a 2-3 shift it feels like it just skips to 4th gear.
Then the car also needs at least one rocker that I know of. Because I changed the oil & found about 20 needle bearings stuck to the drain plug on the oil pan.
But the car still runs like a bat of hell. Even if the car is running on 7 cycl,,, I was told the car has a nice big cam in it. But the car is not choppy at all. It just sounds loud to me & feels pretty fast. Faster then my coupe on motor & it ran 8.0s @86 on motor. So I am just pumped to take the car to Daniel over at SIMPLE QUICK RACING to get it tuned & have them just go over it & check out the things that I have notcied wrong with the car.
So worst case. Mike Katz at Century said he can rebuild the trans for $3650 & that includes a Stage II Rebuild that should hold up to 9 sec power. That price also includes them installing a Trans Cooler & shift Kit & rebuilding my Yank 4200 Converter.
But I want SQR to look the car over first & replace the broken rocker with some bigger Rockers & get the motor tuned & if they say the trans needs a rebuild to get to my goal to run tens. Then I am going to have it rebuilt over at Century Tranmission in Richmond, Texas. Just driving 6 hours one way is going to kill me.
Then go back to SQR & drop about $3000 on the Suspension & put some QA1 Shocks & Struts on it & a Aftermarket Panhard bar & Torqe Arm so I can put all the power to the ground & maybe pick up some Bogarts
