Sneek Peek...
Old Jul 10, 2006 | 03:31 PM
  #41
DJ's Z's Avatar
Originally Posted by Nine Ball
you better call me if you visit Conley's since I only live 8 mi from there.
No prob Tony...hoping maybe toward the end of this week or early next week we'll make a few pulls. I'll give ya a shout unless you've changed your cell lately...talk with ya soon. Bring that monster C-6 out too!!
Old Jul 10, 2006 | 04:23 PM
  #42
the predator's Avatar
good luck, keep us posted!
Old Jul 10, 2006 | 04:26 PM
  #43
ulySSes's Avatar
Originally Posted by ESR
hmmm trash the dyno hmmm...... Dennis Ill catch up with ya tonight so we can see how well this real time tuning works with HPT. It should save us some time.
I'm glad to hear your car is finally running!!
Old Jul 10, 2006 | 04:30 PM
  #44
ESR's Avatar
ESR
LS1TECH Sponsor
Default lol
Yes it is .....and a big thanks to tiago for that.
Old Jul 10, 2006 | 06:57 PM
  #45
SSilverSSurfer's Avatar
its running? sweet, you need to let me check it out eric
Old Jul 10, 2006 | 08:22 PM
  #46
kornfreak_401's Avatar
holy ****!!! wow
Old Jul 11, 2006 | 09:03 AM
  #47
ESR's Avatar
ESR
LS1TECH Sponsor
Default ......
Preliminary street tuning done. Still a few things to work out but over all the car moves. Had some pretty high injector duty cycles on those 75's kinda worried about that the injector pulse widths were around 45 which is pretty high. It is moving though. I m guessing it will be going to the dyno within a week. I let Dennis elaborate on the rest.
Old Jul 11, 2006 | 10:07 AM
  #48
Stang's Bane's Avatar
That is badass Dennis. This is Keith, I have your old motor, been reworking some of my plans, should rock pretty good. Good to see everything is coming along good for you. Sending a pm.
Old Jul 11, 2006 | 10:46 AM
  #49
my number 1 hater's Avatar
clean CLEAN CLEAN ,,, what about HP?????
Old Jul 11, 2006 | 04:18 PM
  #50
DJ's Z's Avatar
Yep as Eric had mentioned we have a few minor things to work out but all in all I'm pretty happy with everything so far...Replaced my old *** O2's today and bumped up the FP to 58psi (at gauge) to help out a little with the duty cycle the injectors are seeing.
Thought for sure the injectors would be enough but I was told wrong. Guess I should have done my own homework instead of listening to someone else...
Hope to have some numbers with in a week or so but until then I'll be out playin' and getting use to the extra 300 or so HP!! It is fun...
Old Jul 11, 2006 | 07:30 PM
  #51
Inspector12's Avatar
TT-TECH Veteran
Well they are the largest high impedance injectors on the market currently I guess you could have tried the Vessatronics (sp) converter to run the Low impedance injectors, but I have herd nothing but bad things about it. Are you boost referencing the regulator? Sounds like you are making a little power though.
Jeff
Old Jul 11, 2006 | 10:53 PM
  #52
ESR's Avatar
ESR
LS1TECH Sponsor
We are using them on tiagos car just takes a bit of time to work some bugs out. Only real issue is the idle but over all not too bad.
Jeff
