engine light HELP
Old Jun 21, 2006 | 06:09 PM
volcanic2345's Avatar
Default engine light HELP
ok i had this light come on before i put my headers on, got a test done and they told me it was the o2's in the back but also said if i was going to put headers on wait and just get o2 sims ok, well last week i got my headers,y-pipe,o2 sims all put on and the guy told me the light should come off after about 80-150 miles that i have to give it time to reset well i have gone way more then that and its still on what should i do? and what does the light do anyways and is there anyway to reset it? thanks
Old Jun 21, 2006 | 06:21 PM
Abe99's Avatar
You can disconnect the battery for a while and the light should go away. The light is just there to warn you that something is wrong.
Old Jun 21, 2006 | 06:31 PM
SleeperZzZ28's Avatar
it shoulda cleared if that was the problem. I would go to autozone or somewhere and have them scan your codes. Its free and youll know what the problem is. Im guessing you probably have a bad one in the front also.
Old Jun 21, 2006 | 07:13 PM
ok went to autozone and said the code was po410 and something about secondary injection system, what does this mean, he said his computer was messed up but to take this code to a shop and they should be able to tell me
Old Jun 21, 2006 | 07:43 PM
AaronR's Avatar
It means you need the rear 02s deleted and probaly need new front 02s.
Old Jun 21, 2006 | 07:46 PM
Doomsday's Avatar
When I ran Shell 93 octane its seemed to make it appear less often. What the hell just tune it.
Old Jun 21, 2006 | 10:29 PM
ok where do the 02 sims come into place they put those in
where is a good place to get it tuned in arlington area
Old Jun 22, 2006 | 08:57 AM
shouldaboughttheZ's Avatar
Have you done a pcm reset? Unplugging the battery will not do it.
The proper way to reset the PCM is key on, car OFF, pull the PCM IGN and PCM BATT fuse from the fuse blocks in the engine bay. Wait 10-15 mins. turn the key off, replace the fuses, start the car.
Old Jun 22, 2006 | 02:48 PM
PERFECT Z28's Avatar
And nothing bad will happen to the car, right?
Just curious.
Old Jun 22, 2006 | 05:04 PM
ZipZ28's Avatar
Just curious.
Right, it'll just clear the codes.
Old Jun 22, 2006 | 07:15 PM
ok iam trying it right now
Old Jun 22, 2006 | 09:40 PM
ok so far so good the light is off now i hope it stays off last time it came back on thanks
Old Jun 23, 2006 | 10:27 AM
Any updates?
Old Jun 23, 2006 | 05:21 PM
it came back on
Old Jun 23, 2006 | 05:38 PM
98 Raptor TA's Avatar
AaronR is wrong about what that code means, it has nothing to do with your O2 sensors. The secondary air injection is talking about your air pump. If you put a cold air intake on the car or something and didn't hook the air pump line up it could be that, or if you deleted the air pump all together. A tune could fix that problem easily. Many people delete their EGR and AIR when the start modding their cars.
Old Jun 23, 2006 | 06:15 PM
well all the guy did was the free mods,headers,ory,lid,cut-out could it have something to do with the free mods, and where can i get it tuned at in arlington are close by and about how much thanks!
Old Jun 23, 2006 | 10:31 PM
Deleting the AIR is a free mod but it could be related to the lid if the air hose insn't connected to the lid, but as far as tuning, speedteck could do, They're by Fort Worth, and i think SQR or RPM is in Fort Worth as well, dont know their prices tho, you might wanna find there website and then give them a call
Old Jun 23, 2006 | 10:44 PM
ok i know what it is now its the little pump that was connect to my stock lid, i have a g2 lid and there was no place to hook the hose up to it so i just took it under something and someone told me that it only has to do with the first 5 sec. the car starts up
Old Jun 23, 2006 | 10:45 PM
and i know where the speedtek in dallas is (its where i bought my headers)
Old Jun 23, 2006 | 10:47 PM
I knew it was prolly that hose, that's what i was talking about in that last post. But yeah it is pretty much only for the first few minutes of warm up, but it will make you engine light come on.
