Wheel bearing replacement? Need instruction (sorta)
Is there a right up on this anywhere to make my life easier or can anyone tell me how its done or the procedure, before i tear into it. It getting bad i just went to tighten the lugs on the rear and the drivers side wheels move about half inch back and forth and it pops when i take off turning left. Well if anyone can that would be appreciated if not then
Slowpoke gave you the super short version.
hubs/bearings are non serviceable. you must replace the whole operation thusly:
Take off wheels, calipers and rotors. Don't forget to disconnect speed sensor. Then the 4 bolts he mentioned come out from the back of the spindle. Recommend massive amounts of PB - those rust on nicely.
The new hub installation is reverse of removal.
